Cisco Systems problem with vlan + arp
Subject Author Date
problem with vlan + arp Matteo 09-07-08
Posted by Matteo on September 7, 2008, 6:27 am
I have this situation, cisco 2811 + some catalyst 3560, connect in
"trunk mode" and other unmanaged switch connect to catalyst 3560 with
port configure in "access mode".
Cisco 2811 term every vlan using sub-inf in "encapsulation dot1q vlan-
id" and doing routing between every vlan.
Sometimes some host connect to unmanaged l2 switch not reply to ping,
this host usually are Access Point Mikrotik or Motorola, but traffic
flow regular, infact if I connect in our l2 domain I can ping
they...... so I type on cisco 2811 on console "clear arp-cache" and
every return to work fine.
I check arp table and it is correct, I disable ip proxy-arp on sub-inf
but nothing.
Every catalyst in trunk mode is connect to other by wireless link by
Alavarion in bridge mode.
I haven't ideaa.... have you somethings that I can try ??
Thank you so much in advance,
Matteo
Posted by Thrill5 on September 8, 2008, 12:06 am
The problem could be that the default arp-cache timeout on the router and
the default mac-address timeout on the switches are different. I have run
into this problem before and I consider this to be a bug (but Cisco
doesn't.) Cisco recommends setting the arp-cache timeout on each VLAN to
300 seconds (which is the default mac-address timeout on the switches) using
"arp timeout 300" on each VLAN interface. After not hearing from that IP
address, the router interface will broadcast an ARP request, and the
switches will relearn which port the MAC address belongs to.
> Hi,
> but nothing.
> Matteo
Posted by Matteo on September 8, 2008, 3:47 pm
Thank you, I add "arp timeout 300" and now I check if it work fine,
tomorrow I reply somethings to you.
Bye
Matteo
> the default mac-address timeout on the switches are different. =A0I have =
run
> doesn't.) =A0Cisco recommends setting the arp-cache timeout on each VLAN =
to
> 300 seconds (which is the default mac-address timeout on the switches) us=
ing
> "arp timeout 300" on each VLAN interface. =A0After not hearing from that =
IP
> > Hi,
> > but nothing.
> > Matteo- Nascondi testo citato
> - Mostra testo citato -
Similar ThreadsPosted
VLAN problem May 11, 2006, 1:03 am
problem with vlan + arp September 7, 2008, 6:27 am
VLAN configuration problem December 19, 2005, 1:11 am
CISCO 2950 vlan config problem August 18, 2005, 9:01 am
cisco1811: mac addresses from vlan interfaces problem November 24, 2006, 7:51 pm
Cisco 877 Router - VLAN/DMZ Configuration/Problem February 15, 2007, 6:07 am
Cisco 3550 VLAN-Internet routing problem March 25, 2006, 7:15 am
Catalyst 3200/LS1010 Vlan trunking problem December 22, 2007, 7:05 am
Cisco Softphone Vlan Versus Preexisting Hardphone Voice Vlan September 23, 2005, 7:43 am
VLAN Security vs. Inter-VLAN Routing December 18, 2007, 4:26 pm
Native, and management vlan "Vlan 1" September 21, 2005, 2:50 pm
User's VLAN and special VLAN August 25, 2006, 11:45 am
VLAN Project and Native VLAN July 13, 2007, 5:06 am
VLAN port with internet access can access only one vlan? April 21, 2006, 3:38 pm
VLAN August 17, 2005, 3:11 pm
