Cisco Systems problem with newly installed serial boards on 2621
Subject Author Date
problem with newly installed serial boards on 2621 Thomas75 04-19-08
Posted by Thomas75 on April 19, 2008, 2:44 am
I just installed the NM-4T 4 port serial board on my 2621 router.
but when I do "show interface", I only see two fastethernet interfaces
and not the newly installed serial board.
is there any extra setup i need to do to make it working?
could it be faulty board?
Thank you for your help
-Thomas
Posted by Merv on April 19, 2008, 5:10 am
AFAIK NM-4T is not supported on 26xx
see Cisco doc
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a00800a93f3.shtml#topic3
I believe only the 1-port or 2-port T1 WIC's are supported on 26xx
Posted by Thomas75 on April 20, 2008, 1:41 am
> see Cisco dochttp://www.cisco.com/en/US/products/hw/routers/ps274/products=
_tech_no...
Thanks for the reply.
Then what kind of serial interface is supported on 2621 router?
I wanted to use that 2621 router as frame relay cloud for my lab.
Can I use the 4 port async serial port then?
Thank you again
-Thomas
Posted by Doug McIntyre on April 20, 2008, 2:22 am
>_tech_no...
WIC-1T/WIC-2T are supported. And are very cheap.
Weren't you the one that had the 3620 that was going to do the NM-4AS?
Or was that somebody else?
Err, I wouldn't recommend it, Frame-Relay really wants to use the
synch serial ports.
Posted by on April 20, 2008, 8:33 am
> > see Cisco dochttp://www.cisco.com/en/US/products/hw/routers/ps274/produc=
ts_tech_no...
> Thank you again
Thanks for pointing this out, would never have occurred to me
and I may be building a lab quite soon. Unless of course I
decide than Dynamips will do the job for me. I do have a lot of
Cisco hands on so I think I will get away with it.
Merv of course means wic-1t and wic-2t.
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186=
a00800b0858.shtml
WIC...T1 is something a bit different:-)
Similar ThreadsPosted
problem with newly installed serial boards on 2621 April 19, 2008, 2:44 am
serial number of installed gbic/sfp January 31, 2006, 8:06 am
Serial interface for 2621 to do frame relay March 25, 2008, 11:20 am
problem with some sites after installed PIX-please help June 21, 2005, 3:12 pm
cisco 2621 problem February 26, 2006, 8:18 am
Problem Configuring 2621 October 1, 2007, 6:55 pm
Issues with WS-X67xx boards October 26, 2005, 6:15 am
cisco line protocal problem on serial interface December 12, 2005, 3:51 pm
Cisco newbie with a routing problem with Cisco 2621 October 25, 2006, 12:49 pm
How to tell if PDM is already installed on a PIX? December 5, 2005, 12:06 pm
Total installed RAM via SNMP? July 13, 2005, 7:00 am
How to find out what kind of GBIC is installed in the CAT switch. March 1, 2006, 5:45 pm
How do you implement SPAN on a 2801 Router with a HWIX-4ESW card installed. January 2, 2007, 4:02 pm
2621 XM February 3, 2006, 9:55 pm
Help w/ WIC-1DSU-T1 in 2621 March 21, 2006, 9:03 pm
