Hi all,
is there a possibility to manage a PRI interface with only 15 timeslots with CCM 3.3 (using MGCP)?
Gateway: 2651XM Module: NM-HDV WIC: VWIC-1MFT-E1
Background: The E1 has 31 timeslots but the upper 15 are disabled by the provider. When dialing out the gateway tries to use timeslot 31, even though "Channel Selection order" has been set to "bottom up". Setting "pri-group timeslots 1-16 service mgcp" on the gateway works until the router is rebooted.
How can I tell the gateway not to use the upper channels permanently?
Dietmar
