pppoe on 802.1q with cos
I search a configuration for a CPE (cisco 800 or 1700 or 1800).
I have tu use an Ethernet port (not the ATM interface, I have a modem). I have to tag all my packet with a vlan ID (ID 2900 so ISL not working) in
802.1q I have to tag all my packet witch CoS (at 2 or 4).
The configuration work if I have the pppoe-client on my interface directly but it's not tagged in 802.1q and my provider need it.
Do you have some other configuration for that ?
The relevant configuration :
! interface FastEthernet0/0 no ip address speed 100 full-duplex pppoe-client dial-pool-number 1 ! ! interface Dialer0 description PPPoE to ISP mtu 1492 ip address negotiated no ip redirects no ip unreachables no ip proxy-arp ip flow ingress ip nat outside encapsulation ppp ip tcp adjust-mss 1452 dialer pool 1 dialer idle-timeout 270 dialer-group 1 keepalive 5 2 ppp authentication pap chap callin ppp chap hostname loing@realm ppp chap password xxxxx ppp ipcp address accept ! ip route 0.0.0.0 0.0.0.0 Dialer0
What I need is somthing like :
interface FastEthernet0/0.2900 no ip address encapsulation dot1Q 2900 pppoe-client dial-pool-number 1 !
but pppoe-client is not supported on subinterface.
Thanks,
jbaudet
