Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by on April 19, 2008, 2:50 pm
Please log in for more thread options cisco router? Also why vpdn group is configured? can anyone please answer my questions. regards, raghur | ||||||||||||||||
Posted by Doug McIntyre on April 20, 2008, 2:14 am
Please log in for more thread options Thats they way they decided to do it?? Ie. you need something to setup the process that will be doing the "dialout" for the PPP, and while for the earlier PPPoA, they used the interface dialer, they chose not to for PPPoE? Probably because they worked on the server end first. The VPDN groups can be used for many more than PPPoE, thats where you end up doing L2F, L2TP, PPTP, as well as PPPoE (server side). When they did the client side, they probably just made it all part of the same, as you would do client-side L2TP through a VPDN group as well. So they did the same for PPPoE within the VPDN group. I guess it seems straightforward enough to me, but I deal with all the above, not just a client PPPoE setup. As I've said before, the cisco routers are more like a hammer and a bunch of boards, rather than a pre-fab kit. You can do so much more, but you have to put some of the pieces together in new ways, but you aren't constrained by the existing design (so much). | ||||||||||||||||
| Similar Threads | Posted |
| pppoe configuration | April 19, 2008, 2:50 pm |
| Pix Configuration (PPPoe, VPN, between 3 sites) | September 10, 2005, 7:20 am |
| PPPoE configuration in cisco 2600 | July 3, 2005, 11:53 pm |
| pppoe server configuration help in cisco 2801 | July 18, 2005, 2:56 am |
| Cisco ASA 5505 configuration for PPPOE/BellSouth | August 12, 2007, 1:25 pm |
| Configuration reverted to previous configuration after power loss | March 3, 2006, 11:14 am |
| PPPOE for DSL | November 7, 2005, 3:16 pm |
| Pix 7.2.1 and PPPoE | June 8, 2006, 6:26 am |
| Pix 501 not getting pppoe IP | December 7, 2006, 1:40 pm |
| Using SCP on 877 with PPPoE | April 9, 2007, 3:55 pm |
| Pix 501 VPN and PPPoe | December 6, 2007, 11:27 am |
| PPPoE | April 10, 2008, 3:59 am |
| pppoe with pix 506 | October 7, 2008, 12:49 am |
| PPPoE/DSL -- no connectivity | February 5, 2006, 2:24 pm |
| 871 and Static PPPoE | October 4, 2006, 6:30 pm |
pppoe configuration
Yahoo!
Windows Live
del.icio.us
digg
Netscape
>cisco router?
