I've got a new site that I'm trying to get wireless working with. There are 10 access points (a mix of 1131s and 1230s), many of which were converted to lightweight mode for use with a 4400 wireless lan controller. All of the access points are run to a Hubbell Powertrac powered patch panel which is intended to supply the Power over Ethernet.The Powertrac supports mostly 802.3af compliant devices, plus a few legacy devices (although Hubbell didn't really have a list of what legacy devices that includes).
The problem is that none of the 1230s are getting any power. My questions are:
- Is the Cisco 1230 802.3af compliant? The Cisco tech handling a TAC case I opened says yes, but the results I'm seeing and some things I've read on the Cisco website suggest otherwise.
- If the powered patch panel is only acting as a normal patch panel port, could I put a Power Injector between switch and the patch panel?
Thanks!
--Steve
