Cisco Systems power injector question
Subject Author Date
power injector question bhawkins 06-11-09
Posted by bhawkins on June 11, 2009, 3:16 pm
I was wondering before I fry one of my Cisco IP phones if I can use an
AIR-PWRINJ3 instead of the IP Phone version to power it, I have a
7971G-GE and a few AIR-PWRINJ3 injectors from a friend who was getting
rid of them at work. It currently runs on the power cube but would
prefer to wall mount it and not have a wire running up the wall.
And if I do use this injector will I loose gigabit and what is the
main difference between the two versions that Cisco has.
TIA
Bhawkins
Posted by Doug McIntyre on June 12, 2009, 12:42 am
The AIR-PWRINJ3 doesn't support gigabit. Just 10/100.
You need the Cisco Unified IP Phone Power Injector (ie. CP-PWR-INJ) to
support 802.3af over Gigabit ethernet support (or a gig switch doing PoE).
They have more than 3 models of power injectors. The main diff
is what devices they target for each, and how much power each can supply.
(ie. some AP operating in certain modes need more power than others).
Date of release is another factor. They essentially all operate the
same otherwise.
I believe the AIR-PWRINJ3 is designed for recent Access Points rather
than the phones.
It should power the phone fine though, but at 100Mbps. I have one
powering an older model Cisco IP Phone.
Similar ThreadsPosted
power injector question June 11, 2009, 3:16 pm
Cisco Aironet 350 A/P power question October 17, 2006, 1:30 am
power off remotely ? September 25, 2005, 1:07 pm
Switches with DC power January 6, 2006, 6:39 pm
Power over Ethernet February 13, 2006, 5:00 pm
Power adapter. May 11, 2006, 12:10 pm
power supply July 16, 2006, 3:11 pm
Power over Ethernet August 23, 2006, 4:18 pm
power outage- can I get around it? June 14, 2005, 12:04 pm
DC Power for WS-C3550-24-SMI May 17, 2007, 9:55 pm
When is RELOAD not the same as a power off/on? September 24, 2009, 9:30 pm
Catylyst 4507r power down September 20, 2005, 11:52 am
Cisco Power over Ethernet PoE November 15, 2005, 11:05 am
Ethernet over ac power lines December 8, 2005, 4:27 pm
6509 power consumption January 24, 2006, 8:07 pm
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
