Guys I have a problem. I'm using Pix506 Firewall, Exchange Server
192.168.2.11 and Symantec Mail Security 8220 Spam Filter 192.168.2.5.The mail traffic is routed from PIX to Spam8220 and Spam 8220 routes it to the Exchange server. When somebody is tried to access its own mailbox from outside. The http traffic is routed directly to the exchange server. Also I route traffic through port 443 from PIX to Spam8220. Spam8220 uses https to connect to Symantec Update Center in the Internet and make updates.
Everything running fine except that it makes the update and at the next day email traffic running fine but the port 443 on the pix is closed. When I type #clear xlate command the update is done immediately and everything is OK up to next day, when shows me again that problem.
I can't understand why that happen only with the traffic through port
433.Anybody have any idea?
That is the config file:
PIX Version 6.x nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password /ZZZZZZZZZ encrypted passwd ZZZZZZZZ encrypted hostname NRP-PIX fixup protocol ftp 21 fixup protocol http 80 fixup protocol h323 1720 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sqlnet 1521 fixup protocol sip 5060 fixup protocol skinny 2000 no fixup protocol smtp 25 names access-list inside_access_out permit tcp any any eq smtp access-list inside_access_out permit tcp any any eq www access-list inside_access_out permit tcp any any eq 443 access-list inside_access_out permit tcp any any eq 3389 access-list inside_access_out permit tcp any any eq domain access-list inside_access_out permit udp any any eq domain access-list inside_access_out permit tcp any any eq 1776 access-list inside_access_out permit tcp any any eq ftp access-list inside_access_out permit icmp any any echo access-list inside_access_out permit tcp any any eq 8080 access-list inside_access_out permit tcp any any eq 2443 access-list vpnacl permit ip 192.168.2.0 255.255.255.0 10.1.1.0
255.255.255.0 pager lines 24 logging on logging trap notifications logging history notifications logging facility 0 logging host inside 192.168.2.12 interface ethernet0 auto interface ethernet1 auto mtu outside 1500 mtu inside 1500 ip address outside zzz.xxx.yyy.96 255.255.252.0 ip address inside 192.168.2.2 255.255.255.0 ip audit info action alarm ip audit attack action alarm ip local pool clientpool 10.1.1.10-10.1.1.36 pdm history enable arp timeout 14400 global (outside) 1 zzz.xxx.yyy.104 netmask 255.255.252.0 global (outside) 1 zzz.xxx.yyy.105 netmask 255.255.252.0 nat (inside) 0 access-list vpnacl nat (inside) 1 192.168.2.0 255.255.255.0 0 0 static (inside,outside) tcp zzz.xxx.yyy.99 25 192.168.2.5 25 netmask 255.255.255.255 0 0 static (inside,outside) tcp zzz.xxx.yyy.99 80 192.168.2.11 80 netmask 255.255.255.255 0 0 static (inside,outside) tcp zzz.xxx.yyy.99 domain 192.168.2.11 domain netmask 255.255.255.255 0 0 static (inside,outside) udp zzz.xxx.yyy.99 domain 192.168.2.11 domain netmask 255.255.255.255 0 0 static (inside,outside) tcp zzz.xxx.yyy.99 443 192.168.2.5 443 netmask 255.255.255.255 0 0access-group inside_access_out in interface inside conduit deny ip any host 81.48.75.223 conduit permit ip any 141.152.97.50 255.255.255.224 conduit permit tcp host zzz.xxx.yyy.99 eq smtp any conduit permit tcp host zzz.xxx.yyy.99 eq www any conduit permit tcp host zzz.xxx.yyy.99 eq domain any conduit permit ip host zzz.xxx.yyy.99 host 141.152.97.35 route outside 0.0.0.0 0.0.0.0 zzz.xxx.yyy.1 1 timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323
0:05:00 si p 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ (inside) host 192.168.2.10 secretkey timeout 5 aaa-server RADIUS protocol radius aaa-server LOCAL protocol tacacs+ aaa-server mytacacs protocol radius no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps tftp-server inside 192.168.2.10 tftp floodguard enable sysopt connection permit-ipsec no sysopt route dnat crypto ipsec transform-set myset esp-des esp-md5-hmac crypto dynamic-map dynmap 20 set transform-set myset crypto map newmap 20 ipsec-isakmp dynamic dynmap crypto map newmap interface outside crypto map vpngroup client authentication TACACS+ isakmp enable outside isakmp policy 10 authentication pre-share isakmp policy 10 encryption des isakmp policy 10 hash md5 isakmp policy 10 group 2 isakmp policy 10 lifetime 86400 vpngroup XXX address-pool clientpool vpngroup XXX dns-server 192.168.2.10 vpngroup XXX wins-server 192.168.2.10 vpngroup XXX default-domain AAAAA.com vpngroup XXX split-tunnel vpnacl vpngroup XXX idle-time 1800 vpngroup XXX password ******** telnet 192.168.2.0 255.255.255.0 inside telnet timeout 10 ssh timeout 5
