Here is my current configuration. It seems to be working great in my test environment. I have two computers connected to this router. InsidePC connected inside (eth1) is able to access files shared on Server which is connected to the outside (eth0). All computers inside are able to ping outside. Outside should have no access/ports open to the inside.
My PC's on my real network have ip address's 172.31.1.1 - 254 /
255.255.0.0 My InsidePC's IP address needs to be 172.31.1.136 subnet 255.255.0.0 Currently in this cisco test environment I have InsidePC set to 172.31.4.136 / 255.255.255.0.Can I change my PIX inside configuration to work with my PC address
172.31.1.136 / 255.255.0.0 ? If possible I would like the inside interface to stay at 172.31.4.10 but possibly the subnet would be 255.255.0.0.Thanks. If that's too confusing then let me know what I need to clarify.
Building configuration... : Saved : PIX Version 6.3(5) interface ethernet0 auto interface ethernet1 100full nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password 8Ry2YjIyt7RRXU24 encrypted passwd 2KFQnbNIdI.2KYOU encrypted hostname pixfirewall domain-name ciscopix.com clock timezone CST -6 clock summer-time CDT recurring fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names name 172.31.13.1 Server name 172.31.4.136 InsidePC object-group service FileShareTCP tcp port-object eq netbios-ssn port-object eq 445 object-group service FileShareUDP udp port-object eq netbios-ns port-object eq netbios-dgm port-object eq 445 access-list FileShare permit tcp host InsidePC host Server object-group FileShareTCP access-list FileShare permit udp host InsidePC host Server object-group FileShareUDP access-list FileShare permit icmp any any pager lines 24 logging on logging console alerts logging monitor alerts logging buffered informational icmp permit any outside icmp permit any inside mtu outside 1500 mtu inside 1500 ip address outside 172.31.13.2 255.255.255.0 ip address inside 172.31.4.10 255.255.255.0 ip audit info action alarm ip audit attack action alarm pdm location InsidePC 255.255.255.255 inside pdm logging informational 100 pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 1 InsidePC 255.255.255.255 0 0 access-group FileShare in interface outside timeout xlate 0:05:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout sip-disconnect 0:02:00 sip-invite 0:03:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local http server enable http 172.31.4.0 255.255.255.0 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable telnet 172.31.4.0 255.255.255.0 inside telnet timeout 5 ssh timeout 5 console timeout 0 terminal width 80 Cryptochecksum:de64665191c7faff9ddde4375cba0cc4 : end [OK]
