Hello - I was wondering if it is possible to setup static mappings to hosts on remote IP subnets that are behind the PIX. For example:
Pix outside 1.1.1.1 Pix inside 172.16.144.1
router 172.16.144.2 int e0 router 172.16.145.1 int e1
host 172.16.145.2
The host has its default gateway at 172.16.145.1 and has full IP connectivity both ways to the PIX and can get out to the internet. Can I do a static NAT or PAT to the host 172.16.145.2? If so how is this accomplished? I have tried this without success, I am able to create static mappings to hosts that are on the same IP subnet as the inside interface but not to hosts that are on remote IP subnets.
Thanks, Ben
