if anyone knows the answer to this, please help! =)
i have a cisco router connected to the outside interface of my pix. the pix is learning 2 IP addresses from this router. The actual interface IP and a HSRP address.
The default route on the pix points to the HSRP address. There is also a secondary default route pointing out of another interface.
my question is, if the HSRP address were to go down (while the actual interface stays up), will the pix use the secondary default route?
my logic is that since the arp entry for the HSRP address will no longer be on the pix, it will know to use the secondary default route...
thanks!
