When we have a power failure our PIX 515 (see below for specs and versions) does not recover. When power is restored. it just has a flashing network light. Power and ACT are both out. Doing a power cycle from the switch seems to make it recover. The unit had been running since June 21st and Sunday the power went out.
I cannot connect to the Console either, It appears to be non-responsive too.
Where do I go from here?
Thanks!
PhoenixPICOBIOS 4.0 Release 6.0 Copyright 1985-1998 Phoenix Technologies Ltd. All Rights Reserved
Build Time: 04/27/99 17:08:34 Polaris BIOS Version 0.09 CPU = Pentium with MMX 200 MHz
640K System RAM Passed 63M Extended RAM Passed 0512K Cache SRAM Passed System BIOS shadowed per limit segment address: EFE5 PIX BIOS (4.0) #0: Tue May 18 16:29:54 PDT 1999 Platform PIX-515 Flash=i28F640J5 @ 0x300Use BREAK or ESC to interrupt flash boot. Use SPACE to begin flash boot immediately. Reading 123392 bytes of image from flash.
PIX Flash Load Helper
Initializing flashfs... flashfs[0]: 9 files, 3 directories flashfs[0]: 0 orphaned files, 0 orphaned directories flashfs[0]: Total bytes: 15998976 flashfs[0]: Bytes used: 11330560 flashfs[0]: Bytes available: 4668416 flashfs[0]: Initialization complete.
Reading image flash:/pix705.bin Launching image flash:/pix705.bin ####################################################################################################################################
64MB RAMTotal NICs found: 3 mcwa i82559 Ethernet at irq 10 MAC: 0050.54fe.ef68 mcwa i82559 Ethernet at irq 7 MAC: 0050.54fe.ef69 mcwa i82559 Ethernet at irq 9 MAC: 0002.b3ad.7fda BIOS Flash=AT29C257 @ 0xfffd8000
Cisco PIX Security Appliance Software Version 7.0(5) Device Manager Version 5.0(5)
Compiled on Mon 10-Apr-06 14:40 by builders System image file is "flash:/pix705.bin" Config file at boot was "startup-config"
moonrazor up 3 mins 36 secs
Hardware: PIX-515, 64 MB RAM, CPU Pentium 200 MHz Flash i28F640J5 @ 0x300, 16MB BIOS Flash AT29C257 @ 0xfffd8000, 32KB
0: Ext: Ethernet0 : address is 0050.54fe.ef68, irq 10 1: Ext: Ethernet1 : address is 0050.54fe.ef69, irq 7 2: Ext: Ethernet2 : address is 0002.b3ad.7fda, irq 9Licensed features for this platform: Maximum Physical Interfaces : 3 Maximum VLANs : 10 Inside Hosts : Unlimited Failover : Disabled VPN-DES : Enabled VPN-3DES-AES : Enabled Cut-through Proxy : Enabled Guards : Enabled URL Filtering : Enabled Security Contexts : 0 GTP/GPRS : Disabled VPN Peers : Unlimited
This platform has a Restricted (R) license.
Serial Number: 403480639
