PIX-501 with multiple outside IP ranges
My company has a PIX-501 in place as a firewall for a few computers in co-location facilities.
It's currently routing traffic for our current set of IP's just fine, but we're adding a second block, which is not contiguous with the first.
Is it possible to give the PIX two outside IP addresses (i.e. the first one in each IP range)?
If not, what are my options? Is it possible to use something akin to promiscuous mode, so that all incoming packets are routed to the appropriate internal address based on 'static (inside,outside)' statements?
-- - Mike
Remove 'spambegone.net' and reverse to send e-mail.
Mike Ruskai
In article , Mike Ruskai wrote: :Is it possible to give the PIX two outside IP addresses
No.
:If not, what are my options? Is it possible to use something akin to :promiscuous mode, so that all incoming packets are routed to the appropriate :internal address based on 'static (inside,outside)' statements?
Giving the PIX two outside IP addresses would mean that the PIX *itself* would respond to pings on the two IPs and would be able to terminate VPN tunnels on the two IPs. You cannot do that on any PIX on a single [logical] interface. (With any 500 series model except the 501 and 510, you can configure multiple logical interfaces per physical interface, with the logical interfaces being distinguished by VLAN tag.)
Fortunately for the purposes you have described, you do not need the PIX *itself* to respond to multiple IPs: you only need the PIX to be able to pass traffic -through- on behalf of multiple IP ranges. And there's no problem with that. Just configure the static, nat, and global statements the way you would normally, ignoring the fact that that the public IPs are not in the same subnet as the PIX's outside interface. The PIX will proxy ARP on behalf of an indefinite number of public IP, and if proxy ARP isn't suitable for your situation, just *route* the additional IP ranges to the PIX outside IP.
Walter Roberson
Please follow the below mwntioned link:
rave
In article , rave wrote: :Please follow the below mwntioned link:
Ummm? Those two links are about VLAN support on PIX. The OP can't use VLANs on his PIX: the OP has a PIX 501, which does not support VLANs in any publically released version.
Walter Roberson
