In article , Christian Winter wrote: :Christian Winter wrote: :> I'm struggling with a pix 501 here that i would like to provide :> dhcp information to its clients but set the default gateway :> to a different router on the inside subnet.
: (OS is 6.2(2)).
:But when I try to do the same for a bigger net the dhcpd :behaves out of line: :PIX1(config): dhcpd option 249 ip 7.192.0.0 172.20.1.254 :results in dhcpd no longer providing a default gateway to :the client and setting client netmask to 255.0.0.0.
:Is that normal/expected/buggy behaviour?
On PIX 6.2 and 6.3, there is no defined behaviour for dhcpd option 249, so being able to enter it at all should be considered a bug.
The only defined options are 66 and 150, both of which have to do with TFTP, and are designed for use with IP Phones.
I suggest you have that "different router" handle the DHCP instead of the PIX. The PIX is not intended to be a sophisticated DHCP server.
