Physical connectors
Hi all,
I am new to cisco routers and currently studying for my ccna, I have router simulation software but it just isn't the same as the real thing. So I was interested in buy a couple of low end routers from ebay. My only problem is that I am unsure of the physical connectivity of an AUI port to an ethernet lan.
What exactly do I need to connect an AUI port to an rj45 port on the switch of my lan?
Thanks in advance.
Vos
vos
Try to look on eBay for "aui tranciever", "aui adapter", "aui ethernet", "aui 10baset", etc. You will find a bunch of them.
Good luck with your study,
Mike
CiscoHeadsetAdapter.com
Found some, thank you for your time, your very quick response and well wishes.
Vos
vos
Also, if your looking for good, inexpensive LAB equipment, Cisco's
1605R is and excelent choice, as it's going for about $60 on eBay these days.
J.Cottingim
jcottingim
Great thanx for the advice, I was actually looking at the 2500 series. Do you sugest the 1605R over any of the 2500 series? Also I was curious, is there a cable that can connect 2 60-pin serial ports of the 2500 series together?? There seem to be very few 2500 series models available with 2 ethernet connections. Thanx again for you time. :)
Vos
vos
There's at least one of reason that you would want a 2500 series router over a 1605R for a CCNA lab...
The 2500 routers can handle more interfaces. The 1605 has 2 ethernet and one WIC slot. (only)
There's really not much the 1605 can't do. - especially if your just working labs. There's no substitute for the real thing.
J.Cottingim
jcottingim
