Cisco Systems ospf on css
Subject Author Date
ospf on css linguafr 04-21-08
Posted by linguafr on April 21, 2008, 5:16 pm
From the documentation I'm reading it seems that the css only supports
plain text ospf keys, while IOS only supports MD5 or nothing at all,
ie. "null". Anyone know if this is the case and if there's a solution
to using ospf between a css and an ios device?
thx
Posted by News Reader on April 21, 2008, 6:12 pm
> thx
Re: IOS plain text OSPF keys:
http://www.cisco.com/en/US/docs/ios/12_2/iproute/command/reference/1rfospf.html#wp1033181
ip ospf authentication-key
To assign a password to be used by neighboring routers that are using
the OSPF simple password authentication, use the ip ospf
authentication-key command in interface configuration mode. To remove a
previously assigned OSPF password, use the no form of this command.
ip ospf authentication-key password
no ip ospf authentication-key
Syntax Description
password
Any continuous string of characters that can be entered from the
keyboard up to 8 bytes in length.
Usage Guidelines
The password created by this command is used as a "key" that is inserted
directly into the OSPF header when the Cisco IOS software originates
routing protocol packets. A separate password can be assigned to each
network on a per-interface basis. All neighboring routers on the same
network must have the same password to be able to exchange OSPF information.
Note The Cisco IOS software will use this key only when authentication
is enabled for an area with the area authentication router configuration
command.
Examples
The following example enables the authentication key with the string
yourpass:
ip ospf authentication-key yourpass
Best Regards,
News Reader
Posted by linguafr on April 21, 2008, 6:34 pm
thx that's the solution.
Similar ThreadsPosted
Re: basic/weird ospf question- ospf gurus need help!!! December 11, 2007, 4:31 am
ospf February 6, 2006, 11:17 am
ospf March 2, 2006, 8:29 pm
OSPF March 2, 2006, 8:53 pm
Useful OSPF Q & A August 24, 2006, 7:50 am
OSPF behind a PIX June 29, 2005, 12:01 pm
ospf June 30, 2005, 1:38 pm
OSPF or BGP January 9, 2007, 2:15 pm
Ospf in VRF April 2, 2007, 4:41 am
ospf on css April 21, 2008, 5:16 pm
EIGRP and OSPF July 24, 2005, 11:42 pm
ospf over mpls August 29, 2005, 7:15 am
OSPF over GRE Tunnels September 25, 2005, 2:25 pm
Lab Challenge 8 - OSPF lab 2 November 2, 2005, 11:13 pm
ip ospf priority November 10, 2005, 11:13 am
