I'm hoping someone out there has the definitive answer to this one, as I'm getting really confused! I've read, and been told, that the network statement for OSPF should be used with subnets on which you only want the OSPF process to run, not for networks you want to advertise out through OSPF (although I've also read the reverse, hence the post). Consider the following (I've changed the IPs but the principles of what I'm experiencing are the same):
Suppose you have a large network and have decided to use 172.16.0.0/16 for all IP devices, subnetting where appropriate. You assign
172.16.1.0/24 through to 172.16.20.0/24 for various departments on one router, and 172.16.21.0/24 through to 172.16.40.0/24 for others on another router. 172.16.254.0/24 is assigned for router management and router-to-router interfaces and is subnetted further, for example:172.16.254.0/30 router 1 to router 2
172.16.254.253/32 router 1 loopback 172.16.254.254/32 router 2 loopbackSnippets of the basic interface config for each router are as follows:
router 1
------------ interface vlan 2 ip address 172.16.2.1 255.255.255.0
interface vlan 3 ip address 172.16.3.1 255.255.255.0
interface vlan 100 ip address 172.16.254.1 255.255.255.252
router 2
------------ interface vlan 10 ip address 172.16.10.1 255.255.255.0
interface vlan 11 ip address 172.16.11.1 255.255.255.0
interface vlan 100 ip address 172.16.254.2 255.255.255.252
Vlan 100 is used to connect the routers together and each router runs one OSPF process:
router ospf 1 passive-interface default no passive-interface Vlan100
So the question is, what exactly should the network statements look like? If you go by the book then it should read something like:
network 172.16.254.0 0.0.0.3 area 172.16.0.0
for each router (or even stricter by referencing the exact IP address with a 0.0.0.0 wildcard mask - apparently this is commonly quoted in cisco material as the method to use).
In this case, the 2 routers will become OSPF neighbours, but will need a 'redistribute connected' statement in order for subnets on router 1 to be advertised to router 2 (and vice versa). The problem here is that router 2 will 'learn' 172.16.1.0/24 as an external route, either type 1 or 2 depending on the metric type specified in the redistribute statement of router 1. ie, 'show ip route 172.16.1.0' on router 2 will have a code of 'O E1' or 'O E2'.
However, if you use the following network statement on each router:
network 172.16.0.0 0.0.255.255 area 172.16.0.0
then you don't need to use 'redistribute connected' and 'show ip route
172.16.1.0' on router 2 will have a code of 'O', ie an internal OSPF route. I'm using 'passive-interface default' to prevent OSPF packets on interfaces that don't have routers connected to them.To me, logic would suggest that routes advertised between routers in the same area should not appear as external and therefore the first method is flawed. Also, the only routes with code 'O' will be the ones used to interconnect the routers together ... or is this what an OSPF code 'O' route indicates? With the 2nd method all routes will be in the routing tables as code 'O', which makes more sense.
On a related matter, if I wanted my area to be a stub area (it is connected to backbone 0, I've just left this out for clarity) I believe none of the routers can be ASBRs ... which they all are due to the prescence of a 'redistribute' statement. Which would suggest that the use of 'redistribute connected' is not the preferred way to go.
Any advice gratefully received.
Darren
