~ hi ~ i have a problems with two nm-16am module in a cisco 3725 ~ 1/ it can only be dialed by a phone line witch is configured in pos as ~ pulse line
Doesn't matter whether the originate modem uses pulses or DTMF when dialing into the NM-16AM. The signaling method is a private matter between the originate modem and the switch on the other end of its POTS line.
~ 2/ i can connect only in V.23 protocol not i V.34 or V.90 protocols
NM-AM AT docs:
I will assume that your want your V.23 calls to use 1200 bps in the answer->originate direction and 75 bps in the originate->answer direction. So you might try a modemcap like this:
&fb0%m0\\n0%b1200%f2
&f - reset to factory defaults b0 - ITU not Bell for low bit rate modulations %m0 - disable V.34 and above \\n0 - normal mode (no EC) %b1200 - max DCE rate 1200 bps %f2 - V.23 transmit 1200 bps, receive 75 bps
For fancier PoS knobs, see
~ 2/ when connecting with V.23 protocol it don't make a PPP negosciation
Right, PoS applications almost never do PPP.
You will probably use a configuration like this:
line modem dialin modem autoconfigure type XXX autocommand telnet 1.2.3.4 /stream /quiet 4444
where 1.2.3.4 is the IP address of your PoS application server and 4444 is the TCP port on which it listens.
Aaron
