not able to receive mail through pix 506e firewall
Hi I have pix 506e firewall, D-link ADSL dsl-502t and my IBM xseries 236 server. I have fix static live ip 59.181.103.220 which i have got from ISP. loyalindia.co.in is my domain, The MX record for it is mail.loyalindia.co.in which points to
59.181.103.220
My problem is i am not able to send mails ( with my mail server, Exchange server,loyalindia.co.in) through pix 506e but i am receiving mails from any server.
I have tried with (ADSL) natting and without natting but the problem is same. If i am removing the pix 506e and directly connecting the server to adsl i am able to receive and send mails properly
My network design is as fallows:- ADSL (WAN) 59.181.103.220 ADSL (LAN)59.181.103.221 Pix 506e (out) 59.181.103.222 Pix 506e (in) 192.168.1.1. My domain mail server loyalindia.co.in (Exchange server) ip
192.168.1.2
My config as fallows:- PIX Version 6.3(5) interface ethernet0 auto interface ethernet1 auto nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password oH2xz4N6pxtBHe8N encrypted passwd.2KYencrypted hostname loyal domain-name loyalfire.com fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 no fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names name 59.181.103.221 adsl name 192.168.1.2 mail access-list smtp_in permit tcp any interface outside eq smtp access-list smtp_in permit tcp any host 59.181.103.222 eq smtp access-list out_in permit tcp any interface outside eq smtp pager lines 24 mtu outside 1500 mtu inside 1500 ip address outside 59.181.103.222 255.255.255.0 ip address inside 192.168.1.1 255.255.255.0 ip audit info action alarm ip audit attack action alarm pdm location mail 255.255.255.255 inside pdm location adsl 255.255.255.255 outside pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 1 0.0.0.0 0.0.0.0 0 0 static (inside,outside) tcp interface smtp mail smtp netmask
255.255.255.255 0 0
access-group out_in in interface outside route outside 0.0.0.0 0.0.0.0 adsl 1 timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout sip-disconnect 0:02:00 sip-invite 0:03:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local http server enable http mail 255.255.255.255 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable telnet timeout 5 ssh timeout 5 console timeout 0 terminal width 80 Cryptochecksum:496f7c38801fe5cffecbc0ba6381a49d : end can anyone support me?
hemanttandel
Posting the message again is not going to change the answer,
You have stated that your MX/A record for the mail server is .220 but your PIX config is for .222 change your A record to reflect .222 not .220
Smokey
Hide quoted text -
Hi If this ip 59.181.103.222 is not live, it will work?. Because i had already done that but it was not sending and receiving mails. The other network design i have made was as fallows:- (59.181.111.159 is new fix static ip but it is not live) The MX/A record for it is mail.loyalindia.co.in which points to
59.181.111.159
ADSL (WAN) 59.181.103.220 ADSL (LAN)59.181.111.158 Pix 506e (out) 59.181.111.159 Pix 506e (in) 192.168.1.1. My domain mail server loyalindia.co.in (Exchange server) ip
192.168.1.2 This network did not solved my problem.
According to you my config is ok but i have to change the MX/A record ip to 59.181.103.222 (pix out ip) instead of 59.181.103.220 and it will solved my problem. Ok i will try this. Any other way to solved problem. waiting for the reply. Bye
hemanttandel
