I don't think this should be too hard, but I have a general question. I setup a Site to Site VPN between a Pix 515 and Pix 501(Easy Enough). The hard part is getting the internal networks to talk. I network the PCs is on connects to a Proxy Server, which then connects to the PIX
515. The PC network is 10.1.0.0/16 and the Proxy Server has an interface on that LAN, and the network directly connected to the PIX 515(192.168.100.0/24) as well. The remote LAN that I'm trying to access is 10.4.1.0/24. My ACL for NONAT is setup between 10.1.0.0 and 10.4.1.0. I'm not sure if I have to NONAT between 192.168.100.0 and 10.4.1.0, and then add a route into the Proxy Server, or if I keep it the way I have, and then add some sort of "route inside or outside" command to the PIX. Any help would be greatly appreciated. A diagram of the config can be found here:- posted
17 years ago
