I've got a project I'm trying to use an l2tpv3 tunnel for. The tunnel seems to establish just fine, but it doesn't seem to do quite what I expected it to do. I'm trying to access vlans on a remote site that's connected via ATM. The remote side is connected by a 3640 router, plus a 8510 switch. On the local side, I've got another 3640, plus a 3500 switch.
As a possible clue, doing a 'show vlans' shows many packets output, but only a few input on the local side. On the remote side, the counts are zero in and out.
Here is a piece of the config on both sides. There is a vlan 77 on the network connected to f0/0 on the remote side that I'd like to be able to assign to the network connected to f0/0 on the local side.
Thanks!
--Steve
=========== remote side ===========
l2tp-class l2-dyn hostname ABC password cookie size 8 ! pseudowire-class pw-dynamic encapsulation l2tpv3 protocol l2tpv3 l2-dyn ip local interface FastEthernet0/0 ! interface FastEthernet0/0 ip address 10.77.0.1 255.255.0.0 no ip redirects no ip proxy-arp ip pim sparse-mode ip route-cache flow speed 100 full-duplex ! interface FastEthernet0/0.77 encapsulation dot1Q 77 no snmp trap link-status no cdp enable xconnect 10.52.0.10 77 pw-class pw-dynamic ! interface ATM1/0.2 multipoint bandwidth 2284 ip address 10.99.60.77 255.255.255.0 ip pim sparse-mode no ip mroute-cache pvc data 0/277 protocol ip 10.99.60.1 broadcast ubr 2284 broadcast encapsulation aal5snap ! !
========== local side ==========
l2tp-class l2-dyn hostname ADM password cookie size 8 ! pseudowire-class pw-dynamic encapsulation l2tpv3 protocol l2tpv3 l2-dyn ip local interface FastEthernet0/0 ! interface FastEthernet0/0 no ip address duplex auto speed auto ! interface FastEthernet0/0.77 encapsulation dot1Q 77 no snmp trap link-status no cdp enable xconnect 10.77.0.1 77 pw-class pw-dynamic ! interface FastEthernet2/0 no ip address no ip redirects no ip proxy-arp ip pim sparse-mode duplex auto speed auto ! interface FastEthernet2/0.52 encapsulation dot1Q 52 native ip address 10.52.0.10 255.255.0.0 no snmp trap link-status !
