Multicast over IPSec Tunnels?
We have an IPSec tunnel required for a client to pass certain types of traffic, but multicast must also be passed.
I stumbled across this from Cisco:
CSCdu87170 o IP multicast traffic cannot be sent over a Generic Routing Encapsulation (GRE) tunnel if IP Security (IPSec) is configured on the tunnel. Other routing protocols may continue to work normally. o Workaround: Remove IP Security (IPSec) configuration from the tunnel or send IP multicast traffic over a different unencrypted tunnel.
I want to confirm is this is the case? If so, is there a way that this can be done? And if not, would the most logical option be to just make a straight GRE tunnel without IPSec and how does one configure Multicast dense-mode over a tunnel.
I believe you just enable "ip multicast-routing" and "ip pim dense- mode" on each relevent interface correct?
I appreciate any thoughts, thanks!
Whatever I Fear
"Where" you stumbled across it is relevant.
When I did a search for CSCdu87170, I found it first in a section titled "Resolved Caveats?Cisco IOS Release 12.1(12)"
Resolved, as in "fixed".
Your platform (not stated), and the IOS release (not stated) you are using are determining factors in whether a workaround is needed.
Best Regards, News Reader
News Reader
I see, thank you for pointing that out, I did not notice the 'resolved', I appreciate it
Whatever I Fear
The particular document I referred too, stated it was resolved (Cisco IOS Release 12.1(12)).
You need to determine whether your installed IOS release pre-dates the fix, or not.
News Reader
