Hi all
consider the following situation:
Customer edge Router (e.g. Cisco 28xx) with a primary link to the provider edge router via an Etherconnect line, i.e. a connection where the carrier provides a modem which is conected to the router. A backup link is established over a steady DSL connection. On both interfaces we have /30 transfer networks an run ospf with the provider edge routers on the other ends.
Now we want to monitor the primary connection from the provider backbone. Usually we do not use ospf and simply ping the customer edge IP adresses of the two transfer networks in order to test their reachability. Now in case of the running ospf this is not an option since both IP addresses would be always reachable as long as one connection is up.
An option would be to monitor the interface status via snmp. That's good as long as a failing connection implies an interface status change to down. Unfortunately this is not the case since the connection to the carrier's modem would always be up.
Well, I've read a lot about tracking objects and routing policies but I'm not sure whether or not (and if yes, how exactly) this would be of any help in this case.
Any suggestions?
Thanks a lot in advance,
Grischa
