Dear all,
I have to configure a Cisco 3620 router to accept any calls which are coming in via a PRI interface. The data shall then be sent via TCP/IP to any host.
One TCP/IP connection per call is required. The TCP/IP connection shall be closed if the line goes down and vice-versa. Depending on the incoming MSN (or dialled number) a different TCP/IP host and port shall be used. The ISDN dial in uses X.31 case A (X.25 over ISDN B-Channel) and modem uses V.22 bis MNP.
The router has following cards installed:
NM-1FEPRI2CE1-B/U NM-30DM
I need some hints in order to find the right documentation. I don't know the name of this "TCP/IP forward" or the specific IOS features required. ANY help greatly appreciated.
Best regards,
Bernhard Roth
