I need to support Multi-link frame relay. Do I need more than IP Plus?
- posted
18 years ago
When you say multi-link frame relay, do you mean bundling at the frame (PVC) level ? If so with service provider switch ?
Cisco only supports FRF.16 for UNI/NNI configuratons. Cisco does not support FRF.15 end-to-end bundling.
I have used Multi-Link PPP over Frame Relay bundling with great sucess, works well and good performance.
Designing and Deploying Multilink PPP over Frame Relay and ATM
