I added and MGCP Gateway onto my network, configured the IOS for the MGCP gateway, configured my CUCM for the MGCP Gateway but when I try to add the gateway in my Route Groups it does not show up on my CUCM.
The 2620xm gateway is configured as follows, also have the gateway configured on the CUCM under devices for a 26xx series mgcp gateway and the nm-hdv module slot for t1 vwic. The gateway does not show up on devices when I add the route group.
Any suggestions would be appreciated. This is for a home lab setup, not production. I am trying to get this to talk across a T1 to a CUCME router.
Thanks,
AN
! ccm-manager mgcp no ccm-manager fax protocol cisco ccm-manager music-on-hold ccm-manager config server 10.1.50.30 ccm-manager config ! mgcp mgcp call-agent 10.1.50.30 2427 service-type mgcp version 0.1 mgcp rtp unreachable timeout 1000 action notify mgcp modem passthrough voip mode nse mgcp package-capability rtp-package mgcp package-capability sst-package mgcp package-capability pre-package no mgcp package-capability res-package no mgcp timer receive-rtcp mgcp sdp simple mgcp fax t38 inhibit mgcp rtp payload-type g726r16 static mgcp behavior g729-variants static-pt ! mgcp profile default ! ! ! gateway timer receive-rtp 1200 !
pgh-vgw1.voice#sh mgcp connection
pgh-vgw1.voice#sh mgcp nas % Incomplete command.
pgh-vgw1.voice#sh mgcp nas ? dump Display MGCP data channel data info Display MGCP data channel information
pgh-vgw1.voice#sh mgcp nas info
pgh-vgw1.voice#sh mgcp statistics UDP pkts rx 20, tx 27 Unrecognized rx pkts 0, MGCP message parsing errors 0 Duplicate MGCP ack tx 0, Invalid versions count 0 CreateConn rx 0, successful 0, failed 0 DeleteConn rx 0, successful 0, failed 0 ModifyConn rx 0, successful 0, failed 0 DeleteConn tx 0, successful 0, failed 0 NotifyRequest rx 0, successful 0, failed 0 AuditConnection rx 0, successful 0, failed 0 AuditEndpoint rx 0, successful 0, failed 0 RestartInProgress tx 21, successful 21, failed 0 Notify tx 0, successful 0, failed 0 ACK tx 0, NACK tx 0 ACK rx 0, NACK rx 20
IP address based Call Agents statistics: IP address 10.1.50.30, Total msg rx 20, successful 0, failed 20 System resource check is DISABLED. No available statistic
DS0 Resource Statistics ----------------------- Utilization: 0.00 percent Total channels: 0 Addressable channels: 0 Inuse channels: 0 Disabled channels: 0 Free channels: 0
pgh-vgw1.voice#sh mgcp MGCP Admin State ACTIVE, Oper State ACTIVE - Cause Code NONE MGCP call-agent: 10.1.50.30 2427 Initial protocol service is MGCP 0.1 MGCP validate call-agent source-ipaddr DISABLED MGCP validate domain name DISABLED MGCP block-newcalls DISABLED MGCP send SGCP RSIP: forced/restart/graceful/disconnected DISABLED MGCP quarantine mode discard/step MGCP quarantine of persistent events is ENABLED MGCP dtmf-relay for VoIP is SDP controlled MGCP dtmf-relay for voAAL2 is SDP controlled MGCP voip modem passthrough mode: NSE, codec: g711ulaw, redundancy: DISABLED, MGCP voaal2 modem passthrough disabled MGCP voip modem relay: Disabled. MGCP T.38 Named Signalling Event (NSE) response timer: 200 MGCP Network (IP/AAL2) Continuity Test timer: 200 MGCP 'RTP stream loss' timer disabled MGCP request timeout 500 MGCP maximum exponential request timeout 4000 MGCP rtp unreachable timeout 1000 action notify MGCP gateway port: 2427, MGCP maximum waiting delay 3000 MGCP restart delay 0, MGCP vad DISABLED MGCP rtrcac DISABLED MGCP system resource check DISABLED MGCP xpc-codec: DISABLED, MGCP persistent hookflash: DISABLED MGCP persistent offhook: ENABLED, MGCP persistent onhook: DISABLED MGCP piggyback msg ENABLED, MGCP endpoint offset DISABLED MGCP simple-sdp ENABLED MGCP undotted-notation DISABLED MGCP codec type g711ulaw, MGCP packetization period 20 MGCP JB threshold lwm 30, MGCP JB threshold hwm 150 MGCP LAT threshold lwm 150, MGCP LAT threshold hwm 300 MGCP PL threshold lwm 1000, MGCP PL threshold hwm 10000 MGCP CL threshold lwm 1000, MGCP CL threshold hwm 10000 MGCP playout mode is adaptive 60, 40, 200 in msec MGCP Fax Playout Buffer is 300 in msec MGCP media (RTP) dscp: ef, MGCP signaling dscp: af31 MGCP default package: line-package MGCP supported packages: gm-package dtmf-package trunk-package line-package hs-package rtp-package atm-package ms-package dt-package mt-package sst-package fxr-package pre-package MGCP Digit Map matching order: shortest match SGCP Digit Map matching order: always left-to-right MGCP VoAAL2 ignore-lco-codec DISABLED MGCP T.38 Max Fax Rate is DEFAULT MGCP T.38 Fax is DISABLED MGCP T.38 Fax ECM is ENABLED MGCP T.38 Fax NSF Override is DISABLED MGCP T.38 Fax Low Speed Redundancy: 0 MGCP T.38 Fax High Speed Redundancy: 0 MGCP control bind :DISABLED MGCP media bind :DISABLED MGCP Upspeed payload type for G711ulaw: 0, G711alaw: 8 MGCP Dynamic payload type for Cisco fax indication: 96, Cisco fax ack: 97 MGCP Static payload type for G.726-16K codec MGCP Dynamic payload type for G.726-24K codec MGCP Dynamic payload type for G.726-32K codec MGCP Dynamic payload type for G.Clear codec MGCP Dynamic payload type for NSE is 100 MGCP Dynamic payload type for NTE is 99 MGCP g729 variants use static payload type and contain annexb in SDP MGCP Guaranteed scheduler time is disabled
pgh-vgw1.voice#
