Manual VLAN pruning on a Cat 3550
I realize that VLANS 1,1002-1005,1006-4094 are prune ineligible with VTP pruning, but I'm wondering about the correct procedure for manually pruning these VLANs from trunks. Since you can manually specify what VLANS are allowed on a trunk, and since you can allow only the VLANS that contain ports on both ends of the trunk, here's the question.....Should you manually prune and observe the prune ineligible VLANS in the 'switchport trunk allowed vlan' statement, or is it OK to only specify the VLANS that are common to the endpoint switches? I'm asking this primarily as to what might be expected on the CCIE Lab exam.
Mikey
Hi Mikey,
You may want to be asking this of the CCIE's on the Cisco Routing and Switching Internetworking Experts Forum:
RouterIE is organized by Brad Ellis, Dual CCIE No. 5796 Security / Routing & Switching:
Sincerely,
Brad Reese BradReese.Com - Cisco Network Engineer Directory
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant Website:
BradReese.Com=A
