X-post to Linux group for Linux insights
Having become frustrated with the lack of flexibility of 'home' routers for my Virgin Cable link, I decided to get a 'proper' router and so bought an old Cisco 871W.
At first look it seemed to fit the bill - vastly configurable but a novice web based interface to manage it initially.
However, because the web software relies on old browsers, but more particularly wants to run in a local JRE on the PC which is much earlier than the current Java release, it doesn't seem to be manageable by anything more recent than a specially configured version of XP with out of date Java.
This, of course, causes certain problems within a SOHO environment where XP is now out of support (with loads of nagging from Microsoft) and general security principles suggest that you shouldn't even have Java installed on your PC, let alone an outdated version.
Also, I am told that reverting Java versions is not an easy thing.
So has anyone tackled this issue successfully?
One option that occurred was to find a Linux distribution which was happy to run old versions of Java and could easily roll back between versions.
Another was a (free) Cisco router [IOS] management tool which didn't rely on a JRE on the PC.
I can do the whole thing in CLI (eventually) but this gives me a very steep learning curve.
Cheers
LGC
