Hello
I want to give a fix address by dhcp to a wirelless access point by is Mac Adress .... but the pb is that this wireless access-point don't keep the fixe address and finally take a dynamic address.... What i have done wrong ?
Thanks for your help
Here is the config
toto.free.fr#show run Building configuration...
Current configuration : 3367 bytes ! ! No configuration change since last restart ! version 12.3 no service pad service timestamps debug uptime service timestamps log uptime service password-encryption ! hostname toto.free.fr ! boot-start-marker boot-end-marker ! enable password 7 xxxx ! clock timezone PCTime 1 clock summer-time PCTime date Mar 30 2003 2:00 Oct 26 2003 3:00 no aaa new-model ip subnet-zero no ip source-route ip cef ! ! no ip domain lookup ip dhcp excluded-address 192.168.0.1 192.168.0.200 ip dhcp excluded-address 192.168.0.210 192.168.0.254 ! ip dhcp pool wifi host 192.168.0.250 255.255.255.0 hardware-address 0100.4005.d042.b8 ! ip dhcp pool 1 network 192.168.0.0 255.255.255.0 default-router 192.168.0.244 dns-server 212.27.32.177 194.149.160.9 ! no ip bootp server ip audit notify log ip audit po max-events 100 no ftp-server write-enable ! ! ! ! interface Null0 no ip unreachables ! interface Ethernet0/0 description connected to EthernetLAN ip address 192.168.0.244 255.255.255.0 ip access-group 100 in no ip redirects no ip unreachables no ip proxy-arp ip nat inside half-duplex ! interface Ethernet0/1 description connected to Internet ip address dhcp ip access-group 103 in no ip proxy-arp ip nat outside half-duplex no cdp enable ! router rip version 1 passive-interface Ethernet0/1 network 192.168.0.0 no auto-summary ! ip nat inside source list 1 interface Ethernet0/1 overload ip nat inside source static udp 192.168.0.10 5555 interface Ethernet0/1 5555 ip nat inside source static tcp 192.168.0.10 5555 interface Ethernet0/1 5555 ip nat inside source static udp 192.168.0.10 6666 interface Ethernet0/1 6666 ip nat inside source static tcp 192.168.0.10 6666 interface Ethernet0/1 6666 no ip http server ip classless ! ! access-list 1 remark Regle NAT genereale access-list 1 permit 192.168.0.0 0.0.0.255 access-list 100 remark LAN In access-list 100 deny ip host 255.255.255.255 any access-list 100 deny ip 127.0.0.0 0.255.255.255 any access-list 100 permit ip any any access-list 102 remark ENTRANT Interface Wan access-list 102 permit udp host 195.83.66.36 eq ntp any eq ntp access-list 102 permit udp any any eq domain access-list 102 permit udp any any eq bootpc access-list 102 permit tcp any any eq 5555 access-list 102 permit udp any any eq 6666 access-list 102 permit tcp any any eq www access-list 102 permit tcp any any eq 5190 access-list 102 permit icmp any any echo-reply access-list 102 permit icmp any any time-exceeded access-list 102 permit icmp any any unreachable access-list 102 deny ip any any access-list 103 remark ENTRANT Interface Wan access-list 103 permit udp any eq bootpc host 192.168.0.244 eq bootpc access-list 103 deny udp any any eq bootps access-list 103 deny udp any any eq snmp access-list 103 deny udp any any eq snmptrap access-list 103 permit ip any any snmp-server community public RO 1 snmp-server enable traps tty banner login ^CAuthorized access only! Disconnect IMMEDIATELY if you are not an authorized user! ****** Acces reserve - Deconnectez vous immediatement ****!^C ! line con 0 exec-timeout 0 0 password 7 xxxxxxx login line aux 0 line vty 0 4 access-class 1 in password 7 xxxxx login ! ntp clock-period 17208599 ntp server 195.83.132.135 ntp server 138.195.130.71 ntp server 195.83.66.36 ntp server 207.46.130.100 ! ! end
