We are currently upgrading our wan links from 64k frame relay connections to full T1 frame relay connections. Currently each branch site has a Cisco 2610 router with an external 64k CSU/DSU connected. We will be swapping those out for Cisco internal WIC-1DSU-T1 cards (v1).
The current config is:
interface Ethernet0/0 ip address 10.x.x.1 255.0.0.0 ! interface Serial0/0 no ip address encapsulation frame-relay no ip mroute-cache no fair-queue frame-relay traffic-shaping frame-relay lmi-type ansi ! interface Serial0/0.1 point-to-point description FR connection to office ip address 10.1xx.x.2 255.0.0.0 frame-relay class cisco frame-relay interface-dlci 100 ... ... ... map-class frame-relay cisco frame-relay adaptive shaping foresight frame-relay cir 64000 frame-relay bc 8000 frame-relay mincir 32000
My plan was to remove the map-class, keep the subinterface as-is minus the class reference, and change the Serial0/0 to:
interface Serial0/0 no ip address encapsulation frame-relay service module t1 clock source internal service module t1 timeslots 1-24 speed 64 service module t1 framing esf service module t1 linecode b8zs fair-que no shut
... my question is does this seem correct or am I missing/overlooking anything? Any help or comments are appreciated.
- Dominic
