Cisco Systems learning destination MAC if default route uses interface and not next-hop IP
Subject Author Date
learning destination MAC if default route uses interface and not next-hop IP Brad 09-20-05
Posted by Brad on September 20, 2005, 11:19 am
I have a router with the following configuration:
service password-encryption
hostname suse_class
ip subnet-zero
no ip domain-lookup
interface FastEthernet0/0
ip address 192.168.100.254 255.255.255.0
no shutdown
no ip proxy-arp
ip nat inside
duplex auto
speed auto
interface FastEthernet1/0
ip address 10.0.0.1 255.255.255.128
ip access-group inboundfilters in
ip access-group outboundfilters out
no ip proxy-arp
ip nat outside
no shutdown
duplex auto
speed auto
ip nat pool suseclass 10.0.0.1 10.0.0.1prefix-length 29
ip nat inside source list 1 pool suseclass overload
no ip classless
no ip forward-protocol udp tftp
no ip forward-protocol udp domain
no ip forward-protocol udp time
no ip forward-protocol udp tacacs
ip route 0.0.0.0 0.0.0.0 FastEthernet1/0
no ip http server
ip access-list extended inboundfilters
evaluate traffic
ip access-list extended outboundfilters
permit tcp any any reflect traffic
permit udp any any reflect traffic
permit icmp any any reflect traffic
access-list 1 permit 192.168.100.0 0.0.0.255
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
The question I have is since I used the interface (fa1/0) in my default
route statement instead of the next-hop IP address how does this router
find out the MAC address for the router on the 10.0.0.0/25 network that
my router is forwarding traffic to out of fa1/0?
Posted by Merv on September 20, 2005, 11:28 am
> how does this router find out the MAC address for the router on the
10.0.0.0/25 > network that > my router is forwarding traffic to out of fa1/0?
It doesn't. It arps for the destination IP address in the outbount
packet and the upstream router responds it it is configured for
proxy-arp.
pointing a static to an interface is a BAD idea; you will want to chane
it to the next hop IP address ( and clear the routers ARP cache (use
shut/no shut if necessary).
Posted by Brad on September 20, 2005, 11:52 am
Thanks for the reply. That makes sense. If the other router had proxy
arp disabled I guess my router would be unable to communicate to the
outside world?
I did notice that the arp cache was huge, but besides that why is it
such a bad idea?
Posted by Merv on September 20, 2005, 12:00 pm
That is why it is abad idea, that ARP cache has to be scanned
continually by the router. Change to use the next IP hop and it you
control the next hop router disable proxy arp on it also.
Similar ThreadsPosted
learning destination MAC if default route uses interface and not next-hop IP September 20, 2005, 11:19 am
Need to route SMTP traffic through static interface (not default route) March 27, 2007, 5:19 pm
Can't set default route to outside interface May 29, 2008, 10:12 pm
What is the default precedence: local-route, static-route, OSPF-route? August 4, 2008, 3:00 am
route based on destination port August 18, 2005, 8:17 am
question for static route -- default route April 1, 2009, 12:03 am
question for static route -- default route April 1, 2009, 12:04 am
RIP + Default Route October 20, 2005, 9:58 pm
Default Route November 4, 2005, 8:05 pm
Default Route(s) August 14, 2006, 11:58 am
Specified a default route by ACL. October 10, 2006, 1:06 pm
Default Route BGP Query December 4, 2006, 8:24 pm
Default Route Question September 4, 2007, 3:32 pm
Pix VPN-Tunnel Default Route? November 22, 2007, 8:15 am
VLAN Default Route October 2, 2008, 12:31 pm
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
