Folks, I have a Pix 515E acting as the IPSec/PPTP end point.I use the CVPN 4.x version for IPSec and MS pptp client for PPTP connection
Issues I face.......
1) With IPSec,I can establish only 1 vpn connection,meaning if another ipsec connection comes in, the existing VPN IPSec connection is kicked out.2) With PPTP, I can get authenticated,but I am unable to browse or ping the internal network.
I have given my configration below....
PIX Version 6.2(2) nameif ethernet0 outside security0 nameif ethernet1 inside security100 nameif ethernet2 dmz security50 enable password dP6LztWI/VQ0Swy0 encrypted passwd qESl5f9ayuCTSGcv encrypted hostname xxx1 domain-name xxx fixup protocol ftp 21 fixup protocol http 80 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol ils 389 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol sip 5060 fixup protocol skinny 2000 fixup protocol domain 53 no names access-list acl_out permit tcp any host xxx.xxx.xxx.30 eq www access-list acl_out permit tcp any host xxx.xxx.xxx.30 eq 3389 access-list acl_out permit tcp any host xxx.xxx.xxx.31 eq smtp access-list acl_out permit tcp any host xxx.xxx.xxx.31 eq pop3 access-list acl_out permit tcp any host xxx.xxx.xxx.31 eq imap4 access-list acl_out permit tcp any host xxx.xxx.xxx.31 eq https access-list acl_out permit tcp any host xxx.xxx.xxx.31 eq 8000 access-list acl_out permit tcp any host xxx.xxx.xxx.30 eq ssh access-list acl_out permit icmp any any access-list acl_out permit tcp any host xxx.xxx.xxx.31 eq www access-list acl_out permit tcp any host xxx.xxx.xxx.37 eq ftp access-list acl_out deny ip any any access-list acl_dmz permit tcp host 10.0.12.243 any eq smtp access-list acl_dmz permit icmp any any echo-reply access-list acl_dmz permit udp 10.0.0.0 255.255.0.0 host
203.166.128.168 eq doma in access-list acl_dmz permit udp 10.0.0.0 255.255.0.0 host 203.166.128.188 eq doma in access-list acl_dmz permit tcp host 10.0.12.242 10.0.11.0 255.255.255.0 access-list acl_dmz permit tcp host 10.0.12.241 10.0.11.0 255.255.255.0 access-list acl_dmz deny ip any any access-list 200 permit ip 10.0.11.0 255.255.255.0 10.0.99.240 255.255.255.240 access-list 200 permit ip 10.0.11.0 255.255.255.0 172.16.9.0 255.255.255.0 pager lines 24 logging on logging trap informational interface ethernet0 auto interface ethernet1 auto interface ethernet2 auto mtu outside 1500 mtu inside 1500 mtu dmz 1500 ip address outside xxx.xxx.xxx.37 255.255.255.192 ip address inside 10.0.11.253 255.255.255.0 ip address dmz 10.0.12.253 255.255.255.240 ip audit name outside info action alarm ip audit name info1 info action alarm ip audit interface outside info1 ip audit info action alarm ip audit attack action alarm ip local pool mc3vpn 172.16.9.1-172.16.9.4 ip local pool vpnppol 10.0.99.241-10.0.99.250 no failover failover timeout 0:00:00 failover poll 15 failover ip address outside 0.0.0.0 failover ip address inside 0.0.0.0 failover ip address dmz 0.0.0.0 pdm history enable arp inside 192.168.4.101 0020.7818.362a arp timeout 14400 global (outside) 1 interface nat (inside) 0 access-list 201 nat (inside) 1 10.0.11.0 255.255.255.0 0 0 nat (dmz) 1 10.0.12.243 255.255.255.255 0 0 static (dmz,outside) tcp xxx.xxx.xxx.31 www 10.0.12.243 8000 netmask 255.255.255 .255 0 0 static (dmz,outside) tcp xxx.xxx.xxx.31 smtp 10.0.12.243 smtp netmask 255.255.25 5.255 0 0 static (dmz,outside) tcp xxx.xxx.xxx.31 8000 10.0.12.243 www netmask 255.255.255 .255 0 0 static (dmz,outside) tcp xxx.xxx.xxx.31 pop3 10.0.12.243 pop3 netmask 255.255.25 5.255 0 0 static (dmz,outside) tcp xxx.xxx.xxx.31 imap4 10.0.12.243 imap4 netmask 255.255. 255.255 0 0 static (dmz,outside) tcp xxx.xxx.xxx.30 3389 10.0.12.241 3389 netmask 255.255.25 5.255 0 0 static (dmz,outside) tcp xxx.xxx.xxx.30 www 10.0.12.241 www netmask 255.255.255. 255 0 0 static (dmz,outside) tcp xxx.xxx.xxx.30 ssh 10.0.12.242 ssh netmask 255.255.255. 255 0 0 static (inside,outside) tcp interface ftp 10.0.11.191 ftp netmask 255.255.255.25 5 0 0 static (inside,dmz) 10.0.11.0 10.0.11.0 netmask 255.255.255.0 0 0 access-group acl_out in interface outside access-group acl_dmz in interface dmz route outside 0.0.0.0 0.0.0.0 xxx.xxx.xxx.1 1 timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si p 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server RADIUS protocol radius aaa-server LOCAL protocol local http server enable no snmp-server location no snmp-server contact snmp-server community public snmp-server enable traps floodguard enable sysopt connection permit-ipsec sysopt connection permit-pptp sysopt route dnat crypto ipsec transform-set myset esp-des esp-md5-hmac crypto dynamic-map dynmap 10 set transform-set myset crypto map mymap 10 ipsec-isakmp dynamic dynmap crypto map mymap interface outside isakmp enable outside isakmp client configuration address-pool local vpnppol outside isakmp policy 10 authentication pre-share isakmp policy 10 encryption des isakmp policy 10 hash md5 isakmp policy 10 group 2 isakmp policy 10 lifetime 86400 vpngroup vpngrp address-pool vpnppol vpngroup vpngrp idle-time 1800 vpngroup vpngrp password ******** vpdn group 1 accept dialin pptp vpdn group 1 ppp authentication pap vpdn group 1 ppp authentication chap vpdn group 1 ppp authentication mschap vpdn group 1 ppp encryption mppe 40 vpdn group 1 client configuration address local mc3vpn vpdn group 1 pptp echo 60 vpdn group 1 client authentication local vpdn username cisco password ********* vpdn enable outside terminal width 80 Cryptochecksum:22652e21edb479617b7c28400427bfe1 : end [OK]Any help would be appreciated.Thanks
