issue when connecting with vpn client
Hello all,
Im getting an 442: Failed to enable Virtual Adapter.error when im trying to connect using my cisco vpn cilent..
Does anyone have an advice on this issue?
My log is:
Cisco Systems VPN Client Version 5.0.05.0290 Copyright (C) 1998-2009 Cisco Systems, Inc. All Rights Reserved. Client Type(s): Windows, WinNT Running on: 6.0.6001 Service Pack 1
44 09:53:39.552 06/08/09 Sev=Warning/2 CVPND/0xE3400003 Function RegisterPrivateInterface failed with an error code of 0x00000000(DRVIFACE:3212)
45 09:53:39.552 06/08/09 Sev=Warning/2 CM/0xE3100008 Failed to register private (virtual adapter) interface
46 09:53:39.755 06/08/09 Sev=Warning/2 CVPND/0xA3400015 Error with call to IpHlpApi.DLL: CheckUpVASettings: Found IPADDR entry addr=10.4.1.158, error 0
47 09:53:40.769 06/08/09 Sev=Warning/2 CVPND/0xA3400015 Error with call to IpHlpApi.DLL: CleanUpVASettings: Was able to delete all VA settings after all, error 0
48 09:53:41.580 06/08/09 Sev=Warning/2 IKE/0xE300009B Failed to active IPSec SA: Unable to enable Virtual Adapter (NavigatorQM:936)
49 09:53:41.580 06/08/09 Sev=Warning/2 IKE/0xE30000A7 Unexpected SW error occurred while processing Quick Mode negotiator:(Navigator:2263)
50 09:53:41.580 06/08/09 Sev=Warning/2 IPSEC/0xA370001F Cannot find binding for the private address: 10.4.1.158
51 09:53:41.580 06/08/09 Sev=Warning/2 IPSEC/0xA370001F Cannot find binding for the private address: 10.4.1.158
52 09:53:41.580 06/08/09 Sev=Warning/2 IPSEC/0xA370001F Cannot find binding for the private address: 10.4.1.158
53 09:53:41.580 06/08/09 Sev=Warning/2 IPSEC/0xA370001F Cannot find binding for the private address: 10.4.1.158
54 09:53:41.580 06/08/09 Sev=Warning/2 IPSEC/0xA370001F Cannot find binding for the private address: 10.4.1.158
55 09:53:41.580 06/08/09 Sev=Warning/2 IPSEC/0xA370001F Cannot find binding for the private address: 10.4.1.158
56 09:53:41.580 06/08/09 Sev=Warning/2 IPSEC/0xA370001F Cannot find binding for the private address: 10.4.1.158
57 09:53:41.580 06/08/09 Sev=Warning/2 IPSEC/0xA370001F Cannot find binding for the private address: 10.4.1.158
58 09:53:41.580 06/08/09 Sev=Warning/2 IPSEC/0xA370001F Cannot find binding for the private address: 10.4.1.158
59 09:53:41.580 06/08/09 Sev=Warning/2 IPSEC/0xA370001F Cannot find binding for the private address: 10.4.1.158
60 09:57:03.678 06/08/09 Sev=Warning/2 CVPND/0xE3400003 Function RegisterPrivateInterface failed with an error code of 0x00000000(DRVIFACE:3212)
61 09:57:03.678 06/08/09 Sev=Warning/2 CM/0xE3100008 Failed to register private (virtual adapter) interface
62 09:57:03.866 06/08/09 Sev=Warning/2 CVPND/0xA3400015 Error with call to IpHlpApi.DLL: CheckUpVASettings: Found IPADDR entry addr=10.4.1.158, error 0
63 09:57:04.880 06/08/09 Sev=Warning/2 CVPND/0xA3400015 Error with call to IpHlpApi.DLL: CleanUpVASettings: Was able to delete all VA settings after all, error 0
64 09:57:05.472 06/08/09 Sev=Warning/2 IKE/0xE300009B Failed to active IPSec SA: Unable to enable Virtual Adapter (NavigatorQM:936)
65 09:57:05.472 06/08/09 Sev=Warning/2 IKE/0xE30000A7 Unexpected SW error occurred while processing Quick Mode negotiator:(Navigator:2263)
66 09:57:05.472 06/08/09 Sev=Warning/2 IPSEC/0xA370001F Cannot find binding for the private address: 10.4.1.158
67 09:57:05.472 06/08/09 Sev=Warning/2 IPSEC/0xA370001F Cannot find binding for the private address: 10.4.1.158
68 09:57:05.472 06/08/09 Sev=Warning/2 IPSEC/0xA370001F Cannot find binding for the private address: 10.4.1.158
69 09:57:05.472 06/08/09 Sev=Warning/2 IPSEC/0xA370001F Cannot find binding for the private address: 10.4.1.158
70 09:57:05.472 06/08/09 Sev=Warning/2 IPSEC/0xA370001F Cannot find binding for the private address: 10.4.1.158
71 09:57:05.472 06/08/09 Sev=Warning/2 IPSEC/0xA370001F Cannot find binding for the private address: 10.4.1.158
72 09:57:05.472 06/08/09 Sev=Warning/2 IPSEC/0xA370001F Cannot find binding for the private address: 10.4.1.158
73 09:57:05.472 06/08/09 Sev=Warning/2 IPSEC/0xA370001F Cannot find binding for the private address: 10.4.1.158
74 09:57:05.472 06/08/09 Sev=Warning/2 IPSEC/0xA370001F Cannot find binding for the private address: 10.4.1.158
75 09:57:05.472 06/08/09 Sev=Warning/2 IPSEC/0xA370001F Cannot find binding for the private address: 10.4.1.158
Steffen Brandsborg Jensen
| Hello all, | | Im getting an 442: Failed to enable Virtual Adapter.error when im trying to | connect using my cisco vpn cilent.. | | Does anyone have an advice on this issue?
Try reinstalling the cisco vpn client.
Morph
Has any one found the solution to this, I am getting the exact same thing.
dcbrown
  1. Uninstall your Cisco VPN Client.
  2. Download and Install the file WinFix ftp://files.citrix.com/winfix.exe 3. Reboot the computer.
  3. Install the DNE Update
ftp://files.citrix.com/dneupdate.msi for 32-bit ftp://files.citrix.com/dneupdate64.msi for 64-bit 5. Install your Cisco VPN Client
  1. Restart Computer
milamna
l'errore indicato dal codice 442
Condivisione connessione Internet (ICS) Per disabilitarlo: Da START -> Cercare SERVIZI -> ARRESTARE Condivisione co
Successivamente riavviare il servizio Cisco Systems, Inc. VPN Service, e ve rificare che entrambi i servizi Cisco siano attivi.
tia.masiero
