Hi, I've a got a Cisco 2610 with ISDN 10 PRI service, and a Cisco 1603 with ISDN BRI service. I dial out from 2610 to 1603. It is very weired that when the 1603 is in another state, (which means I need to put area code when I dial), I can ping from WAN interface of 2610 to WAN interface of 1603. Howerver, if the 1603 is in the same state of 2610, I cannot ping from WAN interface of 2610 to 1603. In both cases, I can see the call is established when I do a "show isdn active". The only difference I could see is: When 1603 is in another state, I can see from 1603 that the call is connected to 0312345678, which is the ISDN
10 number. However, when 1603 is in the same state of 2610. it says the call is connected to unknown. Is this the problem?Please help. Thank you very much.
Config for 2600:
Building configuration...
Current configuration : 1787 bytes ! version 12.2 service timestamps debug uptime service timestamps log uptime service password-encryption service udp-small-servers service tcp-small-servers ! hostname ISDN_MEL_POP ! enable secret 5 xx. ! ip subnet-zero ! ! ! isdn switch-type primary-net5 isdn voice-call-failure 0 ! controller E1 1/0 pri-group timeslots 1-10,16 ! ! ! interface Ethernet0/0 ip address 10.1.7.211 255.255.255.248 half-duplex ! interface BRI0/0 no ip address shutdown isdn switch-type basic-net3 ! interface BRI0/1 no ip address shutdown isdn switch-type basic-net3 ! interface Serial1/0:15 no ip address encapsulation ppp dialer pool-member 1 isdn switch-type primary-net5 isdn bchan-number-order ascending ! interface Dialer0 description ***CMI Kengsington 03 96872355 or 03 96872955*** ip address 10.1.16.101 255.255.255.252 encapsulation ppp dialer pool 1 dialer string 43218765 dialer-group 1 ! interface Dialer1 description ***CMI Campbellfield 03 93577622 or 03 93578722*** ip address 10.1.16.109 255.255.255.252 encapsulation ppp shutdown dialer pool 1 dialer string 0234567812 dialer-group 1 ! ip classless
no ip http server no ip pim bidir-enable ! dialer-list 1 protocol ip permit ! line con 0 exec-timeout 0 0 line aux 0 line vty 0 4 password 7 1234 login ! no scheduler allocate end
Config for 1603: CMI-KENSINGTON#sh running-config Building configuration...
Current configuration: ! version 12.0 service timestamps debug uptime service timestamps log uptime service password-encryption service udp-small-servers service tcp-small-servers ! hostname abc ! enable secret 5 XX ! ip subnet-zero isdn switch-type basic-net3 ! ! ! ! ! interface Ethernet0 ip address 192.168.209.7 255.255.255.0 no ip directed-broadcast no ip route-cache no ip mroute-cache no keepalive ! interface BRI0 ip address 10.1.16.102 255.255.255.252 no ip directed-broadcast encapsulation ppp dialer-group 1 isdn switch-type basic-net3 ! ip classless ip route 0.0.0.0 0.0.0.0 10.1.16.101 ! dialer-list 1 protocol ip permit ! line con 0 exec-timeout 0 0 transport input none line vty 0 4 password 7 123 login ! end
