hello everybody, why can't i make an ISDN call with my 1760 cisco router ?
the IOS version in use is 12.3(18) and the BRI/DIALER configuration is this:
------------------------------------------- interface BRI0/0 no ip address encapsulation ppp dialer pool-member 1 isdn switch-type basic-net3 isdn tei-negotiation first-call isdn point-to-point-setup ppp authentication chap ! interface Dialer1 ip address 10.199.199.4 255.255.255.0 encapsulation ppp dialer pool 1 dialer idle-timeout 180 dialer string xxxxxxxxxxxxxxxxx dialer-group 1 ppp authentication chap callin ppp chap hostname MYUSERNAME ppp chap password MYPASSWORD
here below the debug log with the option dialer events, isdn events and q931, trying to make an ISDN call:
------------------------------------------------- Apr 28 08:53:11.260: BR0/0 DDR: rotor dialout [best] least recent failure is also most recent failure Apr 28 08:53:11.260: BR0/0 DDR: rotor dialout [best] also has most recent failure Apr 28 08:53:11.260: BR0/0 DDR: rotor dialout [best] Apr 28 08:53:11.260: BR0/0 DDR: Dialing cause ip (s=10.199.199.4, d=10.199.199.254) Apr 28 08:53:11.260: BR0/0 DDR: Attempting to dial xxxxxxxxxxxxxxxxx Apr 28 08:53:11.260: ISDN BR0/0 EVENT: UserIdle: callid 0x801C received ISDN_CALL (0x0) Apr 28 08:53:11.264: ISDN BR0/0 Q931: TX -> SETUP pd = 8 callref = 0x1C Bearer Capability i = 0x8890 Standard = CCITT Transfer Capability = Unrestricted Digital Transfer Mode = Circuit Transfer Rate = 64 kbit/s Channel ID i = 0x83 Called Party Number i = 0x80, 'xxxxxxxxxxxxxxxxxx' Plan:Unknown, Type:Unknown Apr 28 08:53:11.476: ISDN BR0/0 Q931: RX
