ISDN call
My remote router is configured to initiate a ISDNdialup to my local router in event of data cct failure.This works as expected. I need to be able to use ISDN to dial INTO the remote router on some occasions even when the data cct is up. I know my authentication is correct but I can't get it working. Would the remote router use their dialer string even if the call is being placed from the other side?
****************************** local router ! interface Dialer4 ip address 10.10.40.1 255.255.255.252 ip nat outside encapsulation ppp no ip route-cache no ip mroute-cache dialer pool 1 dialer remote-name Remote_rtr dialer string 011223344 dialer wait-for-carrier-time 10 dialer redial interval 12 attempts 3 dialer string 0123456 dialer load-threshold 26 either dialer-group 1 no fair-queue no cdp enable ppp authentication chap ppp multilink ! **************************** ! Remote router ! ! interface Serial1/0:15 no ip address encapsulation ppp dialer pool-member 1 isdn switch-type primary-net5 isdn caller 0188776600 isdn caller 0188776500 no cdp enable ppp authentication chap ! ! interface Dialer1 ip address 10.10.40.2 255.255.255.252 encapsulation ppp no ip route-cache no ip mroute-cache dialer pool 1 dialer remote-name Local_router dialer idle-timeout 300 dialer string 018484848 dialer caller 0188776600 dialer caller 0188776500 dialer load-threshold 1 either dialer-group 1 no fair-queue no cdp enable ppp authentication chap ppp multilink ! ************************************** Local_router# 00:22:08: Di4 DDR: Redial: Timeout. Redial on Se1/0:15 for ip (s=10.10.28.14, d=10.10.18.198) (attempt 2) 00:22:08: Se1/0:15 DDR: Attempting to dial 011223344 00:22:08: ISDN Se1/0:15: Outgoing call id = 0x8010, dsl 0 00:22:34359738368: ISDN Se1/0:15: Event: Call to 011223344 at 64 Kb/s 00:22:34359738368: ISDN Se1/0:15: process_pri_call(): call id 0x8010, number 091 386700, speed 64, call type DATA, redialed? f, csm call? f, pdata? f 00:22:34359738432: callED type/plan overridden by call_decode 00:22:34359738432: did't copy oct3a reason: not CALLER_NUMBER_IE 00:22:08: building outgoing channel id for call nfas_int is 0 len is 0 00:22:08: ISDN Se1/0:15: TX ->
Local_router#SETUP pd = 8 callref = 0x0010
00:22:08: Bearer Capability i = 0x8890 00:22:08: Channel ID i = 0xA9839F 00:22:08: Called Party Number i = 0x81, '011223344', Plan:ISDN, Type:Unknown 00:22:08: ISDN Se1/0:15: RX
Ned
Acts like the remote is configured to use "backup interface" to trigger the call, in which case as long as the primary link is active, the dialer is down and cannot be used to answer (or place) any calls. You could change the backup mode to "dial on demand" or "dialer watch" or try defining a separate, independent dialer for dial in. Depending upon how many systems may be dialing in, you may want to consider a virtual template rather than a dialer per caller.
Good luck and have fun!
Vincent C Jones
