I have a task to connect 2 Linux servers using a cross-over cable (but with a twist).
SWITCH | | Server-A - [NIC-A1 , NIC-A2] / / x-over cable / / Server-B - [NIC-B1 , NIC-B2]
NIC-A1 is the only interface connected to a switch. I need to connect Server-B to the same switch but have no more switch ports.
My idea (may be silly) is to run a x-over cable from NIC-A2 to NIC-B1 and thus be on the same VLAN as NIC-A1. For this, I need to somehow internally bridge NIC-A1 and NIC-A2 so when I run the x-over cable, NIC-B1 will be part of the same segment. Then I can assign IP to NIC-B1 and have my L2 connection via Server-A. Is this at all doable???
Thanks Ron
