I want to setup multiple modems to aggregate bandwith between two sites using Cisco CEF Per-Packet and IPSEC crypto maps. I have 5 cable modems, which are connected to a switch, each of them on its own VLAN, and a 802.1q trunk that runs from the switch to Cisco router, to get virtual interfaces to access the modems. Same setup at both sites.
What could I do if the ISP assigns IP addresses that are on the same subnet to each of these modems? i.e. 5 IP addresses are all in the 24.1.2.0/24 subnet? If I try to assign these addresses to the interfaces of the router, it will show an error saying that addresses overlap. Is there a easy way around this problem? Maybe some sort of NAT to hide the external addresses?
Any help appreciated.
Thanks in Advance!
