I have a network with two Cisco Catalyst 3560 switches ( standard image ) and am trying to setup routing between VLANs.
The two switches are connected via fibre and the fibre port is set as a dot1Q trunk ( all VLANs ).
There are a number of VLANs:
VLAN3 192.168.3.0/24 VLAN4 192.168.4.0/24 VLAN5 192.168.5.0/24 etc...
None of these are on the management VLAN.
VTP is up and running across the fibre link so the VLANs are replicating between switches.
When I enable IP routing I can get some semblence of routing going on between VLANs, but not others. For example, a client on VLAN3 can ping another client on VLAN4, but cannot ping a client on VLAN5. VLAN5 can be pinged via the diagnostics utility in the switch though. Another strange one is that an APC UPS connected to one switch can be pinged by IP address from the other switch, but tyring to access the web control panel using the same IP address fails.
When two 3560 switches are configured as above, does IP routing have to be enabled on both switches? If so, what IP addresses should be used for the VLANs?
I have tried using, say, 192.168.3.1 as the IP address for VLAN3 ( on both switches ) but this doesn't seem to make sense.
