Hello,
following situation:
- VPN Server which accepts connections on a Dialer interface
- Incoming VPN connections shall *not* send RDP Queries to PCs connected directly to the Router (Cisco 876)
If I set an ACL to the *Outbound* (RDP denied) direction of the VLAN (on which the PC with the RDP Service is connected) a VPN Client cannot connect to the PC's RDP Service.
And now the question: What is Inbound and Outbound direction in combination of an VLAN interface (NAT inside). All Ethernet Interfaces that are members of the VLAN seem to be Inbound. "VPN incoming data" Outbound ?
