Cisco Systems ifIndex 0 - problem
Subject Author Date
ifIndex 0 - problem kbloomfield 05-06-08
Posted by on May 6, 2008, 2:10 pm
Hello,
I have inherited a management system that is barfing on some cisco
72xx and 76xx routers when it finds an ifIndex = 0, rather than
ifIndex =1 or 10.
I gather that ifIndex =0 is not allowed, but I am not sure by who or
what - so I dont know if it is reasonable for the NMS to ignore
ifIndex = 0 or not.
Nor do I know how the indexes got set to 0 in the ist place, nor hwta
the fix might be (to make all indexes 1 or more.
Can someone hep me out?
TIA
Tony
Posted by on May 7, 2008, 9:32 am
On 6 May, 20:10, kbloomfi...@yahoo.com wrote:
> Hello,
> I have =A0inherited a management system that is barfing on some cisco
> 72xx and 76xx routers when it finds an ifIndex =3D 0, rather than
> ifIndex =3D1 or 10.
> I gather that ifIndex =3D0 is not allowed, but I am not sure by who or
> ifIndex =3D 0 or not.
As I understand it IF indices are set at boot time
automatically and in principle can be re-calculated
at any time thereafter. e.g. if a card is inserted.
More recent IOS is much better behaved
regarding IF indices and does a better job of
maintaining consistent mapping between
indices and interfaces.
It would be surprising if cisco had done anything that
deviated from the standard. Very surprising.
I don't think that it is possible to manually choose
IF indices.
You can check the IF indices for a device yourself
by using getif.exe and browsing to
=2Eiso.org.dod.internet.mgmt.mib-2.interfaces.ifTable.ifEntry.ifIndex
www.wtcs.org/snmp4tpc/getif.htm
Its old code and has limitations but the basics work well.
Its the only free mib browser that I know of.
Posted by on May 11, 2008, 1:10 pm
> > Hello,
> > ifIndex =3D1 or 10.
> IF indices.
> .iso.org.dod.internet.mgmt.mib-2.interfaces.ifTable.ifEntry.ifIndex
Thanks for your reply. After some digging with a mib-browser along the
lines you suggest I confirm you are right about the ifIndex being
correct.
The problem it seems is ipAdEntIfIndex. On each of .routers that
generates a problem message, when interogated by the management
system, there is a ipAdEntIfIndex =3D0.
<sigh> I had a look at the IP-MIB and IF-MIB and I think that there
should not be an ipAdEntIfIndex =3D0. unless there is an ifIndex =3D0
(which there is not and that wouldbe wrong anyway).
But I am not sure.
Can anyone clarify this,plz?
TIA
Kevin
Posted by Merv on May 11, 2008, 5:47 pm
Newer versions of IOS allow one to display the SNMP ifindex values
HUB#show snmp mib ifmib ifIndex
Ethernet0/0: Ifindex = 1
Loopback0: Ifindex = 5
Null0: Ifindex = 4
VoIP-Null0: Ifindex = 3
FastEthernet1/0: Ifindex = 2
Loopback999: Ifindex = 6
You can check the Ifindex values displayed against the Ifindex values
being received by NMS system
Posted by on May 12, 2008, 7:15 am
> Null0: Ifindex = 4
Thanks Merv,
Probably it was not clear in my posting but it is the ipAdEntIfIndex
which are wrong ie there are ipAdEntIfIndex=0 returned by an snmpwalk.
The ifIndexes are fine - they start from 1..
Kevin
Similar ThreadsPosted
ifIndex 0 - problem May 6, 2008, 2:10 pm
PIX Problem February 11, 2005, 2:45 am
PIX problem .. July 12, 2005, 10:27 am
NAT-PT and TCP problem July 20, 2005, 12:25 pm
problem with FTP July 21, 2005, 8:11 pm
PIX 501 Problem July 23, 2005, 9:18 pm
FXO Problem? July 23, 2005, 9:15 pm
pix problem July 27, 2005, 8:13 pm
PIX 501 - problem August 4, 2005, 5:58 pm
pix to pix problem :) August 23, 2005, 4:53 pm
pix 5.3(2) dns problem September 2, 2005, 6:44 am
VTP Problem September 12, 2005, 10:51 am
PIX 520 VPN problem September 21, 2005, 1:50 pm
NAT Problem October 5, 2005, 6:25 am
E1 problem December 9, 2005, 7:16 am
