I've gone and broke my 837 sdm and web interface (uk dsl)
I've had the web interface and sdm running fine on my 837 but I tried to install a newer version of the sdm and since then I can't use either. The sdm install states that there's not enough memory to install the express version on to the router. The web interface just hangs for ages. However there is a logon prompt for the router .
Does anyone know if there any way that I can get this working again without doing a factory reset? I do have http running on port 8080 and https enable too.
Cheers,
Dave
Dave
You need to free up space on the flash and then reinstall SDM manually on the router. Telnet or console to the router and delete all the ".tar" files and all the files in the /html directory. Don't delete the IOS image or the configuration file. You will need to have at least twice the size of the SDM tar file plus 20% free. TFTP the new version of SDM to the router (will be a ".tar" file) and then use the "archive" command to expand the tar file. Cisco has lots of documentation that can provide you with further details.
A "factory reset" will not fix this problem..
Thrill5
Thanks for your help. I've done as said and I'm left with this below. Do I need to delete all the files in the webflash directory too? I've got some advice from some web sites etc but I'm requesting a 2nd opinion from a real human being if you don't mind?
Cheers,
Dave
gateway#dir all Directory of system:/
2 dr-x 0 memory 1 -rw- 2940 running-config 9 dr-x 0 vfiles
No space information available Directory of nvram:/
120 -rw- 2940 startup-config 121 ---- 4059 private-config
131072 bytes total (124021 bytes free) Directory of flash:/
1 -rw- 6307656 c837-k9o3y6-mz.123-4.T7.bin 2 -rw- 16264 sdm.shtml.hide 3 -rw- 1462 home.html.hide 9 -rw- 1723 sdmconfig-83x.cfg
12320768 bytes total (4018812 bytes free) Directory of webflash:/
1 -rw- 792 ConfigExp.cfg 2 -rw- 474217 CRWSbHlp.html 3 -rw- 941455 CRWS_1.jar 4 -rw- 278042 CRWS_2.jar 5 -rw- 62561 CRWS_VPNLogin.jar 6 -rw- 47026 GUI.html 7 -rw- 4895 home.html 8 -rw- 252 IPCPSubnet.cfg 9 -rw- 8082 loading.gif 10 -rw- 3463 VPNLogin.html
1835008 bytes total (13568 bytes free) gateway# gateway# gateway#
Dave
The 800 series used to ship with CRWS, which is the predecessor to SDM. Since you are now using SDM, you don't need those files anymore. Check out this document which should help you out.
Thrill5
