Hi Guys,
I have a strange issue on HSRP. Has anyone encountered such an issue before ? I had to shutdown the standby switch so I made sure all the vlans are active on the primary switch. On reboot of secondary switch, Vlan 23 below which was active on the primary switch went from Active to Init state and remained in that state till the secondary switch came back up.
Actually there were 12 vlans out of which 4 got stuck in Init, the others remained active. I have truncated the config and am focusing only on the below 3 vlans which depict the whole scenario else mentioning all the 12 Vlans was making the whole explanation below too long. Do let me know if you need any more information.
------------------------------------------------------------------------- Before shutting down standby:
C6509-01# sh standby brief P indicates configured to preempt. | Interface Grp Prio P State Active Standby Virtual IP Vl21 0 200 P Active local 10.65.33.253
10.65.33.254 Vl22 0 200 P Active local 10.65.34.253 10.65.34.254 Vl23 0 200 P Active local 10.65.50.3 10.65.50.1------------------------------------------------------------------------- When I shut down standby:
C6509-01#sh standby brief P indicates configured to preempt. | Interface Grp Prio P State Active Standby Virtual IP Vl21 0 200 P Active local unknown
10.65.33.254 Vl22 0 200 P Active local unknown 10.65.34.254 Vl23 0 200 P Init unknown unknown 10.65.50.1------------------------------------------------------------------------- Configuration on active side:
interface Vlan21 ip address 10.65.33.252 255.255.255.0 ip igmp snooping querier standby ip 10.65.33.254 standby priority 200 standby preempt ! interface Vlan22 ip address 10.65.34.252 255.255.255.0 standby ip 10.65.34.254 standby priority 200 standby preempt ! interface Vlan23 ip address 10.65.50.2 255.255.255.0 standby ip 10.65.50.1 standby priority 200 standby preempt
------------------------------------------------------------------------- Configuration on secondary switch ( which was rebooted ):
interface Vlan21 ip address 10.65.33.253 255.255.255.0 ip igmp snooping querier standby ip 10.65.33.254 standby preempt ! interface Vlan22 ip address 10.65.34.253 255.255.255.0 standby ip 10.65.34.254 standby preempt ! interface Vlan23 ip address 10.65.50.3 255.255.255.0 standby ip 10.65.50.1 standby preempt
