(c) 1986-2004 by Cisco Systems, Inc. Compiled Fri 29-Oct-04 07:34 by cmong
ROM: System Bootstrap, Version 12.3(11r)T1, RELEASE SOFTWARE (fc1)
Router uptime is 1 minute System returned to ROM by reload at 09:22:14 UTC Wed Sep 30 2009 System image file is "flash:c3825-adventerprisek9-mz.123-11.T2.bin"
Configuration register is 0x2102
router#sh rom-monitor ReadOnly ROMMON version:
System Bootstrap, Version 12.3(11r)T1, RELEASE SOFTWARE (fc1) Technical Support:
(c) 2004 by cisco Systems, Inc.
No upgrade ROMMON programmed or not yet run Currently running ROMMON from ReadOnly region ROMMON from ReadOnly region is selected for next boot
router uptime is 1 hour, 5 minutes System returned to ROM by reload at 09:22:14 UTC Wed Sep 30 2009 System image file is "flash:c3825-adventerprisek9-mz.123-11.T2.bin"
This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
If you require further assistance please contact us by sending email to snipped-for-privacy@cisco.com.
Cisco 3825 (revision 1.0) with 490495K/33792K bytes of memory. Processor board ID FHK0848F0N5
36 FastEthernet interfaces
2 Gigabit Ethernet interfaces
1 Serial(sync/async) interface
1 terminal line
1 Virtual Private Network (VPN) Module
1 cisco ids sensor(s), ids monitoring on slot 1 DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
OK. Well you have enough DRAM and hopefully just enough flash. 128M flash is recommended but it looks as if the image will fit as long as there is nothing else there. Of course:( you truncated the sh flash output so I cannot see what else there is:) You might even have room for a crashdump.
Image is 60303612 bytes. You won't be able to have any of the web based config tools installed.
By the way the "T" train images are for the latest greatest hardware support and features. Best to use mainline (no T) unless there are features that you know you need.
12.4T will (probably) become 12.5 in due course. Once they call it 12.5 no new features are added and all changes are bug fixes. So 12.4 has had 24 bug fix releases and 12.4T has had 24 new features releases (and of course the bug fixes too). The T train is therefore more likely to be less stable.
