Hi ever one
I have 2 connection from router 2811 to isp but i cant operate only one to internet . how i can operate the second
Best Saiim
Hi ever one
Best Saiim
| Hi ever one | | I have 2 connection from router 2811 to isp but i cant operate only | one to internet . | how i can operate the second
What exactly do you want to do with the second connection? You can configure it as a standby internet link using the IP SLA feature. When the first internet link would go down the router would automaticaly switch to the second.
There are many combinations for your question :
Which option ?
Further to your questions:
If "no" to the above questions, you may have the following questions:
HI Thank you for your reply What I have are 2 connection. the first is leased line with internet access and public IP. the second connection is ADSL, and both line connect to one router cisco 2811. my Q? are
1- How can I configure the 2 connection to work as load balance. 2- How can I configure the router to manage the traffic to use one of the connection depending on protocols to or ports ?Best
Salim
Hi, you seem want to surf the internet only ( but no incoming traffic
-- no internet service to outsider ) ?
many solutions:
Cheers
Hi
No, I use the leased line for VPN connection to an other side and e- mail service like (Exchange OWA), and the ADSL for internet only.
Best Salim
So you want the leased to sevice two purposes ( VPN and Exchange ) & and ADSL line for internet surfing ?
Not so difficult for this solution:
Due to IP addresses of item 1 are fixed ( loaned from the local ISP ? ):
Cheers
