Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Howie on September 25, 2008, 2:04 am
Please log in for more thread options hi, guys. Recently I was trying to implement an IP PBX for my company, but I stuck by the jitter issue. I have a cisco 1760 router with a 10baset WIC-1ENET card, and a cisco 2560G switch, data on vlan1 (native) , voice on vlan2. Already applied Qos on the router. Everything went good at first, but when I was trying to download a big file from the internet, things happened. Here's how I did, I made a call from a ip phone to a landline phone, then put the line onhold, landline phone user can hear the on hold music, then I started to download a big file from internet, the landline user will hear music became jitter. Cant find a way to avoid it, any advice? Thanks in advance. | ||||||||||||||||
Posted by fugettaboutit on September 25, 2008, 7:54 pm
Please log in for more thread options Howie wrote: Be sure to implement CBWFQ/LLQ on the output queue of your serial links. We utilize the exact same platform in part of our network, and I can tell you that we can absolutely bury a T1 without any side effects to the VoIP stream. We might see jitter increase by a millisecond or two, but the overall jitter numbers are just that - less than a handful (< 5ms). We routinely see jitter numbers of < 1 ms. Forty (40) ms is your jitter budget. This is one thing Cisco can do well, as they have superb packet scheduling capabilities in IOS. Do a search on CCO for "CBWFQ/LLQ". Keep it simple, and don't create more than 3 or four total traffic classes. Utilize the VoIP examples they list. Failing that, post your QoS config. Rest assured, though, what you're trying to do is not unreasonable, and done daily in production networks. Good luck! | ||||||||||||||||
Posted by Howie on September 26, 2008, 2:16 pm
> Howie wrote:
> > hi, guys.
> > stuck by the jitter issue. >
> > 2560G switch, data on vlan1 (native) , voice on vlan2. Already applied > > Qos on the router. >
> > file from the internet, things happened. >
> > then put the line onhold, landline phone user can hear the on hold > > music, then I started to download a big file from internet, the > > landline user will hear music became jitter. >
> > Thanks in advance.
> Be sure to implement CBWFQ/LLQ on the output queue of your serial links. > We utilize the exact same platform in part of our network, and I can > tell you that we can absolutely bury a T1 without any side effects to > the VoIP stream. We might see jitter increase by a millisecond or two, > but the overall jitter numbers are just that - less than a handful (< > 5ms). We routinely see jitter numbers of < 1 ms. Forty (40) ms is your > jitter budget. > > This is one thing Cisco can do well, as they have superb packet > scheduling capabilities in IOS. Do a search on CCO for "CBWFQ/LLQ". Keep > it simple, and don't create more than 3 or four total traffic classes. > Utilize the VoIP examples they list. > > Failing that, post your QoS config. Rest assured, though, what you're > trying to do is not unreasonable, and done daily in production networks. > > Good luck! Hi, fugettaboutit, thanks for the input, here is my startup-config: Building configuration... Current configuration : 3394 bytes ! version 12.4 service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname DC1760 ! boot-start-marker boot-end-marker ! no logging buffered enable secret 5 $1$c2hG$1vueVcFX1/Rqdwg3uXxZu1 ! no aaa new-model ! resource policy ! clock timezone Pacific -8 clock summer-time Pacific date Apr 6 2003 2:00 Oct 26 2003 2:00 mmi polling-interval 60 no mmi auto-configure no mmi pvc mmi snmp-timeout 180 ! ! no ip dhcp use vrf connected ip dhcp excluded-address 192.168.1.1 ip dhcp excluded-address 10.0.0.1 10.0.0.99 ip dhcp excluded-address 10.0.1.1 10.0.1.99 ! ip dhcp pool 1_0 network 10.0.0.0 255.255.255.0 dns-server 10.0.0.1 default-router 10.0.0.1 ! ip dhcp pool 2_0 network 10.0.1.0 255.255.255.0 dns-server 10.0.1.1 default-router 10.0.1.1 ! ! ip cef ip ftp username anonymous ip name-server 67.100.88.27 ip name-server 64.105.172.27 ! ! ! ! ! ! class-map match-any SDM-Transactional-1 match protocol citrix match protocol finger match protocol notes match protocol novadigm match protocol pcanywhere match protocol secure-telnet match protocol sqlnet match protocol sqlserver match protocol ssh match protocol telnet match protocol xwindows class-map match-any SDM-Signaling-1 match protocol h323 match protocol rtcp match protocol sip class-map match-any SDM-Routing-1 match protocol bgp match protocol egp match protocol eigrp match protocol ospf match protocol rip match protocol rsvp class-map match-any SDM-Voice-1 match protocol rtp audio class-map match-any SDM-Management-1 match protocol dhcp match protocol dns match protocol imap match protocol kerberos match protocol ldap match protocol secure-imap match protocol secure-ldap match protocol snmp match protocol socks match protocol syslog ! ! policy-map SDM-QoS-Policy-1 class SDM-Voice-1 set dscp ef priority percent 55 class SDM-Signaling-1 set dscp cs3 bandwidth percent 5 class SDM-Routing-1 set dscp cs6 bandwidth percent 5 class SDM-Management-1 set dscp cs2 bandwidth percent 5 class SDM-Transactional-1 set dscp af21 bandwidth percent 5 class class-default fair-queue random-detect ! ! ! ! ! interface FastEthernet0/0 no ip address speed auto ! interface FastEthernet0/0.1 encapsulation dot1Q 1 native ip address 10.0.0.1 255.255.255.0 ip nat inside ip virtual-reassembly no snmp trap link-status ! interface FastEthernet0/0.2 encapsulation dot1Q 2 ip address 10.0.1.1 255.255.255.0 ip nat inside ip virtual-reassembly no snmp trap link-status ! interface FastEthernet0/0.3 description $ETH-LAN$ encapsulation dot1Q 3 ip address 192.168.1.1 255.255.255.0 ip nat inside ip virtual-reassembly no snmp trap link-status ! interface Ethernet1/0 description $ETH-WAN$ ip address 74.xx.xx.78 255.255.255.248 ip nbar protocol-discovery ip nat outside ip virtual-reassembly full-duplex service-policy output SDM-QoS-Policy-1 ! ip route 0.0.0.0 0.0.0.0 74.xx.xx.73 ip http server no ip http secure-server ! ip nat inside source list 1 interface Ethernet1/0 overload ip nat inside source static 10.0.1.2 74.xx.xx.76 ! ip dns server ! access-list 1 remark SDM_ACL Category=3D2 access-list 1 permit 10.0.0.0 0.0.0.255 access-list 1 permit 10.0.1.0 0.0.0.255 access-list 1 permit 192.168.1.0 0.0.0.255 ! ! control-plane ! ! line con 0 line aux 0 line vty 0 4 login ! end I have to say this network is my test environment, so we dont have serial port on 1760, I just connect my wic-1enet card to my netpioa T1 router's ethernet port, dont know whether this will cause the issue. | ||||||||||||||||
| Similar Threads | Posted |
| how to avoid voip jitter | September 25, 2008, 2:04 am |
| Jitter Question | June 15, 2007, 4:19 pm |
| Variable jitter with PPP Multilink | May 15, 2007, 12:42 pm |
| How to avoid filtered status report - PIX. | June 20, 2005, 6:05 pm |
| Avoid Password Recovery on Cisco 5300 | October 6, 2005, 5:15 pm |
| How to avoid getting BGP routes while getting a router's routing table | January 24, 2006, 10:39 am |
| Trying to avoid slow response time with ADSL when there is traffic | January 18, 2006, 1:56 pm |
| child jitter vs parent shaping vs child class-default on 871 and 1841 | February 23, 2007, 8:28 am |
| Voip Updated Howto,Voip ATT Home (October Update) | October 29, 2006, 9:00 am |
| Voip Updated Howto,Voip AT Home | June 28, 2006, 9:02 pm |
| VOIP | June 21, 2006, 2:18 pm |
| Allow VOIP through PIX 501 | July 10, 2006, 3:54 am |
| FAX + VoIP - T.30 / T.38 | August 22, 2006, 4:20 pm |
| VoIP over VPN | August 28, 2006, 4:16 am |
| Voip and QoS | August 28, 2007, 4:54 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> Qos on the router.
> Thanks in advance.
