Hi all --
I know this one has been gone over a lot, however I'm stuck. Reading through and trying the various messages on this topic has not helped.
I have an internal (192.168.1.x) server that is hosting FTP. Works fine internally.
I want to PAT with the CISCO Pix 506E so that users can FTP into the server and upload files, download, etc.
So far nothing has worked, neither the PDM nor the command line. I've enclosed the configuration below. This has taken far longer than I expected, I would greatly appreciate any help.
[I can SSH to an outside box, no problem. But I can't FTP from that box back into the server "Canal" ]pixfirewall# show config : Saved : Written by ******** at 17:40:56.188 GMT/BDT Wed May 24 2006 PIX Version 6.3(5) interface ethernet0 auto interface ethernet1 auto nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password _________________ encrypted passwd ________________________ encrypted hostname pixfirewall domain-name me.com clock timezone GMT/BST 0 clock summer-time GMT/BDT recurring last Sun Mar 1:00 last Sun Oct 2:00 fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names name 192.168.1.xx Canal object-group service SSH_group tcp port-object eq ssh object-group service FTP_group tcp description FTP port-object eq ftp object-group service webservices tcp port-object eq ftp access-list outside_access_in remark SSH access-list outside_access_in permit tcp any object-group SSH_group any object-group SSH_group access-list outside_access_in remark FTP Service access-list outside_access_in permit tcp any object-group FTP_group any object-group FTP_group access-list outside_access_in remark FTP access-list outside permit tcp any host Canal eq ftp pager lines 24 mtu outside 1500 mtu inside 1500 ip address outside 75.7.239.233 255.255.255.0 ip address inside 192.168.1.1 255.255.255.0 ip audit info action alarm ip audit attack action alarm pdm location Canal 255.255.255.255 outside pdm logging informational 100 pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 1 0.0.0.0 0.0.0.0 0 0 static (inside,outside) Canal 75.7.239.233 netmask 255.255.255.255 0 0 access-group outside_access_in in interface outside route outside 0.0.0.0 0.0.0.0 75.7.239.238 1 route outside 75.7.239.233 255.255.255.255 75.7.239.238 1 route outside 75.7.239.233 255.255.255.255 Canal 2 timeout xlate 0:05:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout sip-disconnect 0:02:00 sip-invite 0:03:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local aaa authentication ssh console LOCAL http server enable http 192.168.1.0 255.255.255.0 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable telnet timeout 5 ssh 192.168.1.0 255.255.255.0 inside ssh timeout 5 console timeout 0 dhcpd address 192.168.1.2-192.168.1.254 inside dhcpd dns 206.13.29.12 206.13.30.12 dhcpd lease 1048575 dhcpd ping_timeout 750 dhcpd enable inside
