Help needed with Cisco Aironet 1220 reset
I recently bought one of these on eBay (with an A radio), all worked fine, confugred etc, nothing to complicated, basic encryption etc.
Anyways, 6 weeks down the line, it's stopped working(not sure if the wirelss link is still working, i no longer have a client), it no longer accepts the user name and pasword when connecting to it via HTTP to configure it( i am not miss typing it )
Not a big deal, i'll reset it.......... it is a huge deal!! None of the documents on cisco work??? So I am stuck with abit of hardware worth £600 that isn't working!
Can anyone help, I am fiarly new to cisco, I have a working Cisco PIX
501 running my internet, so that should tell you what level I am at!
Anyways, with the console pluged in, this is what appears when i reboot (remove power, attatch power)
Testing DRAM... (press to bypass) DRAM OK Power-on reset.
Copyright 1996-2000 Cisco Systems, Inc. Copyright 1984-2000 Wind River Systems, Inc.
System ID: 000FF7500A58 Motherboard: IBM405 200MHz, 8192KB FLASH, 16384KB DRAM, Revision 05 Bootstrap Ver. 1.00: FLASH, CRC 1C914641 (OK) Initialization: OK
Memory Bank total used left DRAM 16742624 0 16742624 Config 524288 444 523844 FLASH 7602176 1478172 6124004
Memory Bank:File address size encoding type flags a) Config:AP Installation Key FF820000 80 none Key
0000 b) Config:AWC_ConfigDB FF820050 364 AiroDB1 Data 0000 c) FLASH :EnterpriseAP Sys 12.01A FF8A0000 1213908 gzip Exec 0901 d) FLASH :EnterpriseAP Web 12.01 FF9C85D4 147060 .tar.gz Web 0000 e) FLASH :Inflate Ver. c14o FF9EC448 7496 gzip Dcdr 0900 f) FLASH :350 Series FW 5.02.12 FF9EE190 54388 .tar.gz Data 0000 g) FLASH :AIR-CB20A FW 5.02.12 FF9FB604 55240 .tar.gz Data 0000 h) FLASH :AP Installation Key FFA08DCC 80 none Key 0000
Inflating "EnterpriseAP Sys 12.01A"...
3326684 bytes OK
AwcVlanCfgEntry_t::UpdateReferences(4095): entered : allowEn=0 allowUnen=1 AwcVlanCfgEntry_t::UpdateReferences(4095): exit : allowEn=1 allowUnen=1 AwcVlanCfgEntry_t::UpdateReferences(4095): entered : allowEn=1 allowUnen=1 AwcVlanCfgEntry_t::UpdateReferences(4095): exit : allowEn=1 allowUnen=1 AwcVlanCfgEntry_t::UpdateReferences(4095): entered : allowEn=1 allowUnen=1 AwcVlanCfgEntry_t::UpdateReferences(4095): exit : allowEn=1 allowUnen=1 AwcVlanCfgEntry_t::UpdateReferences(4095): entered : allowEn=1 allowUnen=1 AwcVlanCfgEntry_t::UpdateReferences(4095): exit : allowEn=1 allowUnen=1 Loaded driver for device "emac0", ifIndex=1. Slot 1: Empty
** Failed to Load Driver for device entry #2 (errno=0x006d0001). Slot 2: AIR-CB20A Radio found Loaded driver for device "awc1", ifIndex=4. Configured device "emac0" as IP address "192.168.5.22", network mask 0xffffff00. Attaching network interface lo0... done. Configured device "lo0" as IP address "127.0.0.1", network mask 0x00000000.
Adding 2 symbols for standalone.
00:00:36 (Warning): Backbone Connectivity Lost. Switching to repeater to re-establish link to primary network.
00:00:49 (Warning): Lost Authentication with Parent
00:00:49 (Warning): Lost Authentication with Parent Please enter username: (0)
Any help would be appreciated
bizkitsboiler
could oyu tell us what you have tried and what the results were?
Fuzzy Britches
I basically tried...........
holding the mode button in while powering up
and the reset document which says press "esc" at bootup via console to bring up other menus, no luck!
i'm major confused
bizkitsboiler
Thank you for the speedy reply, unfortunatley it is that exact document that does not seem to work!
I do not see any summary screen or anything simlar during boot up, only what I have pasted here already.
The line "Type within 5 seconds for menu" never appears, am I being a wally or something?
Also if there is a problem with the ethernet, why am I able to ping it and attempt to conenct to it via HTTP?
Thanks
PS, I am new to this google groups thing
bizkitsboiler
Your a star!
I was always looking at the Ctrl X command for the older ones. It's Ctrl W I needed
Thanking for pinting it out that although mine says 1.00 it's the new
1.00 so it was newer than 1.02!
Brilliant!
Thank you so much!
bizkitsboiler
Your a star!
Thanking for pointing it that out, although mine says 1.00 it's the new
Brilliant!
Thank you so much!
bizkitsboiler
snipped-for-privacy@gmail.com schrieb:
Ok. You have a VxWorks AP "
"For password recovery/factory reset procedure.
the "AP Installation Key" is still there. Good. Never, never, never delete this file from Flash.
The Configuration is deleted by formatting the Config: and then copying the Installation Key back from Flash to Config.
the MiniPCI slot is empty
the CardBus slot has a A Radio
The FastEthernet link cannot be established, so the AP falls back to repeater
but cannot find a root AP to associate.
Doublecheck ethernet connection, Duplex setting. If this doesn't help a factory reset procedure is described in the link above.
Uli Link
This document was written for the older AIR-340. So the your Bootloader
1.0 is newer than the 1.02 shown. So this one (1.02 and later) is for you. I never recovered any VxWorks 1200 (they all run IOS), but a few 340 and 350. And it always worked with a straight-through wired serial cable.
Uli Link
