Sorry to post so much info, but I still cannot figure out the problem. I turned on ip-route cache again. But the problem persists. So my config for the main interfaces now looks like this:
--------- interface Ethernet0 ip address 192.168.0.1 255.255.255.0 ip nat inside ! interface Serial0 description Connect to M2K-TOT ip address 204.57.130.54 255.255.255.252 ip nat outside no fair-queue
-------- I booted the machine and waited a few minutes and then ran the commands as described in the previous post. I'll wait 20 more and post again. You will see that the IP Input process keeps rising. It got to 91% at one point before I had to reboot.
---***** SH RUN ****----- Current configuration: ! ! No configuration change since last restart ! version 12.1 service timestamps debug uptime service timestamps log uptime no service password-encryption service udp-small-servers service tcp-small-servers ! hostname TheOrchid ! enable secret 5 $1$X5U7$dntiuJpq9ln7g65X1XulQ1 enable password 1234 ! ! ! ! ! clock timezone BKK 7 ip subnet-zero ip ftp username Philt ip ftp password birdnest7 ip name-server 204.57.160.129 ip name-server 204.57.128.67 ! ip dhcp pool network1 network 192.168.0.0 255.255.255.0 domain-name m2khotspot dns-server 204.57.160.129 204.57.128.67 default-router 192.168.0.1 lease 30 ! partition flash 2 8 8 ! ! ! ! interface Ethernet0 ip address 192.168.0.1 255.255.255.0 ip nat inside ! interface Serial0 description Connect to M2K-TOT ip address 204.57.130.54 255.255.255.252 ip nat outside no fair-queue ! interface Serial1 no ip address no ip route-cache no ip mroute-cache shutdown ! interface BRI0 no ip address shutdown ! ip nat inside source list 1 interface Serial0 overload ip nat inside source list 7 interface Serial0 overload ip nat inside source static tcp 192.168.0.254 8989 204.57.130.54 8080 extendable ip nat outside source static tcp 204.57.130.54 8080 192.168.0.254 8989 extendabl e ip classless ip route 0.0.0.0 0.0.0.0 204.57.130.33 ip route 0.0.0.0 0.0.0.0 204.57.130.53 no ip http server ! access-list 1 permit 192.168.0.0 0.0.0.255 access-list 7 permit 192.168.0.0 0.0.0.255 ! line con 0 transport input none line aux 0 transport input all line vty 0 password 1234 logging synchronous login line vty 1 4 password 1234 login ! ntp clock-period 17179875 ntp server 204.57.160.2 end
-----**** SH INT ****------ BRI0 is administratively down, line protocol is down Hardware is BRI MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation HDLC, loopback not set Last input never, output never, output hang never Last clearing of "show interface" counters 00:01:46 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/0/16 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out 0 carrier transitions BRI0:1 is administratively down, line protocol is down Hardware is BRI MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation HDLC, loopback not set Keepalive set (10 sec) Last input never, output never, output hang never Last clearing of "show interface" counters 00:01:49 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/0/16 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out 0 carrier transitions BRI0:2 is administratively down, line protocol is down Hardware is BRI MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation HDLC, loopback not set Keepalive set (10 sec) Last input never, output never, output hang never Last clearing of "show interface" counters 00:02:10 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/0/16 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out 0 carrier transitions Ethernet0 is up, line protocol is up Hardware is Lance, address is 0010.7b7f.d00d (bia 0010.7b7f.d00d) Internet address is 192.168.0.1/24 MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters 00:02:13 Queueing strategy: fifo Output queue 0/40, 0 drops; input queue 0/75, 0 drops 5 minute input rate 24000 bits/sec, 49 packets/sec 5 minute output rate 17000 bits/sec, 6 packets/sec 6859 packets input, 431784 bytes, 0 no buffer Received 42 broadcasts, 0 runts, 0 giants, 0 throttles 14 input errors, 0 CRC, 0 frame, 0 overrun, 14 ignored 0 input packets with dribble condition detected 776 packets output, 624846 bytes, 0 underruns 0 output errors, 1 collisions, 0 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out Serial0 is up, line protocol is up Hardware is HD64570 Description: Connect to M2K-TOT Internet address is 204.57.130.54/30 MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, reliability 255/255, txload 3/255, rxload 1/255 Encapsulation HDLC, loopback not set Keepalive set (10 sec) Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters 00:02:38 Queueing strategy: fifo Output queue 0/40, 0 drops; input queue 0/75, 0 drops 5 minute input rate 12000 bits/sec, 1 packets/sec 5 minute output rate 20000 bits/sec, 48 packets/sec 798 packets input, 613033 bytes, 0 no buffer Received 19 broadcasts, 0 runts, 0 giants, 0 throttles 1 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 7990 packets output, 422202 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out 0 carrier transitions DCD=up DSR=up DTR=up RTS=up CTS=up Serial1 is administratively down, line protocol is down Hardware is HD64570 MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation HDLC, loopback not set Keepalive set (10 sec) Last input never, output never, output hang never Last clearing of "show interface" counters 00:02:40 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/0/256 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out 0 carrier transitions DCD=down DSR=down DTR=down RTS=down CTS=down
-----***** SH PROC CPU *****--------
CPU utilization for five seconds: 30%/3%; one minute: 24%; five minutes: 16% PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 1 24 76 315 0.00% 0.00% 0.00% 0 Load Meter 2 5964 150 39760 0.00% 0.00% 1.12% 2 Virtual Exec 3 1528 92 16608 0.00% 0.37% 0.26% 0 Check heaps 4 4 1 4000 0.00% 0.00% 0.00% 0 Chunk Manager 5 12 4 3000 0.00% 0.00% 0.00% 0 Pool Manager 6 0 2 0 0.00% 0.00% 0.00% 0 Timers 7 4 2 2000 0.00% 0.00% 0.00% 0 Serial Backgroun 8 228 90 2533 0.00% 0.03% 0.01% 0 ARP Input 9 0 3 0 0.00% 0.00% 0.00% 0 DDR Timers 10 4 2 2000 0.00% 0.00% 0.00% 0 Dialer event 11 28 2 14000 0.00% 0.00% 0.00% 0 Entity MIB API 12 0 1 0 0.00% 0.00% 0.00% 0 SERIAL A'detect 13 0 1 0 0.00% 0.00% 0.00% 0 Critical Bkgnd 14 188 120 1566 0.00% 0.01% 0.00% 0 Net Background 15 8 7 1142 0.00% 0.00% 0.00% 0 Logger 16 128 369 346 0.00% 0.00% 0.00% 0 TTY Background 17 48 388 123 0.00% 0.00% 0.00% 0 Per-Second Jobs 18 0 1 0 0.00% 0.00% 0.00% 0 ISDN From Driver 19 104 129 806 0.00% 0.00% 0.00% 0 Net Input 20 56 77 727 0.08% 0.01% 0.00% 0 Compute load avg 21 308 7 44000 0.00% 0.05% 0.03% 0 Per-minute Jobs 22 63224 5066 12480 26.62% 18.95% 11.77% 0 IP Input 23 2092 58 36068 0.00% 0.85% 0.42% 0 CDP Protocol 24 0 1 0 0.00% 0.00% 0.00% 0 X.25 Encaps Mana 25 4 2 2000 0.00% 0.00% 0.00% 0 Emulator 26 0 1 0 0.00% 0.00% 0.00% 0 PPP IP Add Route 27 204 22 9272 0.00% 0.04% 0.00% 0 IP Background 28 48 8 6000 0.00% 0.01% 0.00% 0 Adj Manager 29 32 15 2133 0.00% 0.00% 0.00% 0 TCP Timer 30 8 2 4000 0.00% 0.00% 0.00% 0 TCP Protocols 31 0 1 0 0.00% 0.00% 0.00% 0 Probe Input 32 0 1 0 0.00% 0.00% 0.00% 0 RARP Input 33 4 1 4000 0.00% 0.00% 0.00% 0 HTTP Timer 34 0 1 0 0.00% 0.00% 0.00% 0 Socket Timers 35 16 2 8000 0.00% 0.00% 0.00% 0 DHCPD Receive 36 488 7 69714 0.00% 0.15% 0.08% 0 IP Cache Ager 37 0 1 0 0.00% 0.00% 0.00% 0 COPS 38 0 1 0 0.00% 0.00% 0.00% 0 PAD InCall 39 8 2 4000 0.00% 0.00% 0.00% 0 X.25 Background 40 0 1 0 0.00% 0.00% 0.00% 0 ISDN Timer 42 4 2 2000 0.00% 0.00% 0.00% 0 Router Autoconf 43 0 1 0 0.00% 0.00% 0.00% 0 CallMIB Backgrou 44 0 1 0 0.00% 0.00% 0.00% 0 ISDNMIB Backgrou 45 0 1 0 0.00% 0.00% 0.00% 0 SNMP ConfCopyPro 46 1624 3982 407 0.65% 0.50% 0.31% 0 IP NAT Ager 47 120 398 301 0.00% 0.00% 0.00% 0 NTP 49 0 4 0 0.00% 0.00% 0.00% 0 DHCPD Timer 50 44 119 369 0.00% 0.00% 0.00% 0 DHCPD Database
-----***** SH INT SWITCHING *****--------
Interface BRI0 is disabled
Interface BRI0:1 is disabled
Interface BRI0:2 is disabled
Ethernet0 Throttle count 0 Drops RP 0 SP 0 SPD Flushes Fast 0 SSE 0 SPD Aggress Fast 0 SPD Priority Inputs 0 Drops 0
Protocol Path Pkts In Chars In Pkts Out Chars Out Other Process 0 0 42 2520 Cache misses 0 Fast 0 0 0 0 Auton/SSE 0 0 0 0 IP Process 20097 1248347 1067 113859 Cache misses 1124 Fast 949 118626 1054 1016786 Auton/SSE 0 0 0 0 ARP Process 90 5400 13 780 Cache misses 0 Fast 0 0 0 0 Auton/SSE 0 0 0 0 CDP Process 0 0 7 2203 Cache misses 0 Fast 0 0 0 0 Auton/SSE 0 0 0 0 Serial0 Connect to M2K-TOT Throttle count 0 Drops RP 0 SP 0 SPD Flushes Fast 0 SSE 0 SPD Aggress Fast 0 SPD Priority Inputs 0 Drops 0
Protocol Path Pkts In Chars In Pkts Out Chars Out Other Process 2 321 42 924 Cache misses 0 Fast 0 0 0 0 Auton/SSE 0 0 0 0 IP Process 966 84480 19367 1008945 Cache misses 42 Fast 1054 1004608 949 109136 Auton/SSE 0 0 0 0 CDP Process 7 2114 13 3774 Cache misses 0 Fast 0 0 0 0 Auton/SSE 0 0 0 0 Interface Serial1 is disabled
