Cisco Systems help IP pass through
Subject Author Date
help IP pass through deano 05-30-08
Posted by deano on May 30, 2008, 2:23 pm
I have been given a group of ip address from the service provider
and I want to be able to use these address directly and also have
anothe group of address which are being NATed is this posable
Posted with NewsLeecher v3.9 Final
Web @ http://www.newsleecher.com/?usenet
Posted by Trendkill on May 30, 2008, 2:29 pm
> Web @http://www.newsleecher.com/?usenet
What is the IP range. As long as you can subnet it, yes you can carve
out some addresses and others for static. However, your network
device may not support 'passing addresses through', and you may need
to install a switch on the outside of your router for the static
addresses, and use a switch on the inside that will hold your private
range that you are using for NAT.
Similar ThreadsPosted
help IP pass through May 30, 2008, 2:23 pm
Re: help IP pass through May 30, 2008, 2:58 pm
Re: help IP pass through May 30, 2008, 3:35 pm
Re: help IP pass through May 30, 2008, 4:38 pm
VPN-1 Secureremote pass-through on a PIX 506 December 30, 2005, 12:34 pm
VPN Not able to pass traffic. January 6, 2006, 11:45 am
Cisco PIX pass through VPN November 16, 2005, 6:54 pm
Cisco PIX pass through VPN November 16, 2005, 6:55 pm
PIX 704 Connat pass traffix December 8, 2005, 2:00 pm
837 vs 857 PPTP Pass through Problems May 8, 2006, 9:39 pm
cisco 76x and PPTP pass through? June 18, 2006, 3:49 pm
pptp pass thru cisco 857 July 26, 2006, 8:27 am
Pass-Guaranteed.com Now Hiring!!! January 10, 2007, 6:27 pm
Pass IT exams by TEST104 November 6, 2007, 3:52 am
Need to pass vlan info over ATM April 23, 2008, 9:35 am
